led and siren
hey I was hopeing some one could join the 2 codes 2 gether please I can not work it out secong post at bottom of page thx
{added code tags, all fixed - Moderator}
/*This code is developed by Raebel Christo.
* The code is made for anyone who wishes to make police lights
* for projects or just for fun can use this and edit as they wish.
* If you are publishing this on youtube, it would be nice to credit it
* and finally subscribe youtube channel 'Raebel Christo' for more fun
* DIY arduino projects.
void setup(){
 pinMode(13,1); // Blue LED on pin 13
 pinMode(12,1); //  "    "  "   "  12
 pinMode(11,1); //  "    "  "   "  11
 pinMode(10,1); // White "  "   "  10
 pinMode(9,1); //   "    "  "   "  9
 pinMode(8,1); // Red    "  "   "  8
 pinMode(7,1); //   "    "  "   "  7
 pinMode(6,1); //   "    "  "   "  6
void loop(){
 for(int i=0;i<15;i++){
 for(int i=0;i<5;i++){
 digitalWrite(12,1);
 digitalWrite(13,1);
 digitalWrite(11,1);
 digitalWrite(10,1);
 digitalWrite(9,0);
 digitalWrite(8,0);
 digitalWrite(7,0);
 digitalWrite(6,0);
 delay(50);
 digitalWrite(12,0);
 digitalWrite(13,0);
 digitalWrite(11,0);
 digitalWrite(10,0);
 digitalWrite(9,0);
 digitalWrite(8,0);
 digitalWrite(7,0);
 digitalWrite(6,0);
 delay(50);
 delay(50);
 digitalWrite(12,0);
 digitalWrite(13,0);
 digitalWrite(11,0);
 digitalWrite(10,0);
 digitalWrite(6,1);
 digitalWrite(9,1);
 digitalWrite(8,1);
 digitalWrite(7,1);
 delay(50);
 digitalWrite(12,0);
 digitalWrite(13,0);
 digitalWrite(11,0);
 digitalWrite(10,0);
 digitalWrite(9,0);
 digitalWrite(8,0);
 digitalWrite(7,0);
 digitalWrite(6,0);
 delay(50);
 delay(50);
 for(int i=0;i<50;i++){
   digitalWrite(12,1);
 digitalWrite(13,1);
 digitalWrite(11,1);
 digitalWrite(10,1);
 digitalWrite(6,0);
 digitalWrite(9,0);
 digitalWrite(8,0);
 digitalWrite(7,0);
 delay(100);
 digitalWrite(12,0);
 digitalWrite(13,0);
 digitalWrite(11,0);
 digitalWrite(10,0);
 digitalWrite(6,1);
 digitalWrite(9,1);
 digitalWrite(8,1);
 digitalWrite(7,1);
 delay(100);
int i=0;
 pinMode(9, OUTPUT);
 for(i=700;i<800;i++){
 tone(9,i);
 delay(15);
 for(i=800;i>700;i--){
 tone(9,i);
 delay(15);
What's this stuff at the end supposed to be doing?
int i=0;
 pinMode(9, OUTPUT);
 tone(9,i);
 delay(15);
 tone(9,i);
 delay(15);
Nested for loops with the same variable?
            digitalWrite(12,1);
Ok, try this. I put the stuff from the 2nd setup() into the first setup(), and the stuff from the 2nd loop() into the first loop().
Then deleted the extra stuff.
It compiles, I don't know if it does what you want. Try it and see.
int i = 0;
  pinMode(13, 1); // Blue LED on pin 13
  pinMode(12, 1); //  "    "  "   "  12
  pinMode(11, 1); //  "    "  "   "  11
  pinMode(10, 1); // White "  "   "  10
  pinMode(9, 1); //   "    "  "   "  9
  pinMode(8, 1); // Red    "  "   "  8
  pinMode(7, 1); //   "    "  "   "  7
  pinMode(6, 1); //   "    "  "   "  6
  pinMode(9, OUTPUT);
  for (int i = 0; i < 15; i++) {
    for (int i = 0; i < 5; i++) {
      digitalWrite(12, 1);
      digitalWrite(13, 1);
      digitalWrite(11, 1);
      digitalWrite(10, 1);
      digitalWrite(9, 0);
      digitalWrite(8, 0);
      digitalWrite(7, 0);
      digitalWrite(6, 0);
      delay(50);
      digitalWrite(12, 0);
      digitalWrite(13, 0);
      digitalWrite(11, 0);
      digitalWrite(10, 0);
      digitalWrite(9, 0);
      digitalWrite(8, 0);
      digitalWrite(7, 0);
      digitalWrite(6, 0);
      delay(50);
    delay(50);
      digitalWrite(6, 1);
      digitalWrite(9, 1);
      digitalWrite(8, 1);
      digitalWrite(7, 1);
      delay(50);
      digitalWrite(9, 0);
      digitalWrite(8, 0);
      digitalWrite(7, 0);
      digitalWrite(6, 0);
      delay(50);
    delay(50);
  for (int i = 0; i < 50; i++) {
    digitalWrite(6, 0);
    digitalWrite(9, 0);
    digitalWrite(8, 0);
    digitalWrite(7, 0);
    delay(100);
    digitalWrite(6, 1);
    digitalWrite(9, 1);
    digitalWrite(8, 1);
    digitalWrite(7, 1);
    delay(100);
  for (i = 700; i < 800; i++) {
    tone(9, i);
    delay(15);
  for (i = 800; i > 700; i--) {
    tone(9, i);
    delay(15);
the bit at the bottom I need joined into the code so I can have the lights and siren noise but everytime I join them it comes up with an error
can you get it to play the siren noise and have the lights is what im trying to do
Not I, that's fancier than I can manage.
Blackfin:
Nowt wrong with that. Might not be a great practice for we humans to keep track of as we read the code, but the uC seems to have no trouble keeping track of the scope.
From quick test sketch both using "i":
Outer 0
  Inner 0
  Inner 1
Outer 1
  Inner 0
  Inner 1
Outer 2
  Inner 0
  Inner 1
OP, see if this works for you. Compiles but not tested. A little fuzzy in the head so it's probably wonky...
Had to move the siren to pin 5 as pin 9 was already used for white#2. Not sure if that'll work for tone or not. If not, swap the W#2 to pin 5 and the siren to pin 5 and change the constants below to match.
const byte pinB1 = 13;
const byte pinB2 = 12;
const byte pinB3 = 11;
const byte pinW1 = 10;
const byte pinW2 = 9;
const byte pinR1 = 8;
const byte pinR2 = 7;
const byte pinR3 = 6;
const byte pinSiren = 5;
const byte grpinLights[] =
    pinB1, pinB2, pinB3,
    pinW1, pinW2,
    pinR1, pinR2, pinR3
    for( int i=0; i<8; i++ )
        pinMode( grpinLights[i], OUTPUT );
    pinMode( pinSiren, OUTPUT );
}//setup
#define INCREASING      0
#define DECREASING      1
void SirenStateMachine( void )
    static byte
        stateSiren = INCREASING;
    static unsigned int
        freqSiren = 700;
    static unsigned long
        timeSiren = 0;
    if( millis() - timeSiren < 15 )
        return;
    timeSiren = millis();
    tone( pinSiren, freqSiren );
    switch( stateSiren )
        case    INCREASING:
            freqSiren++;
            if( freqSiren == 800 )
                stateSiren = DECREASING;
        case    DECREASING:
            freqSiren--;
            if( freqSiren == 700 )
    }//switch
}//SirenStateMachine
    SirenStateMachine();
    LightsControl();
}//loop
void LightsControl( void )
        timeLights = 0,
        timeLightsDelay = 0;
    static bool
        state = false;
    static byte
        outer = 0,
        inner = 0;
    unsigned long
        timeNow;
    timeNow = millis();
    if( (timeNow - timeLights) < timeLightsDelay )
        return;
    timeLights = timeNow;
    if( outer < 15 )
        if( inner < 5 )
            if( state == false )
                state = true;
                DriveLights( 0b00001111 );
                timeLightsDelay = 50;
            }//if
                state = false;
                DriveLights( 0b00000000 );
                inner++;
                if( inner < 5 )
                    timeLightsDelay = 100;
            }//else
        }//if
        else if( inner < 10 )
                state = true;
                DriveLights( 0b11110000 );
                state = false;
                inner++;
                outer++;
                if( inner < 10 )
            }//else
        }//if
    }//if
    else if( outer < 65 )
            state = true;
            state = false;
            outer++;
        }//else
    }//elseif
        //reset
        outer = 0;
        inner = 0;
    }//else
}//LightsStateMachine
void DriveLights( byte pattern )
    byte
        mask = 0x01;
        digitalWrite( grpinLights[i], (pattern & mask)?HIGH:LOW );
        mask <<= 1;
    }//for
}//DriveLights
elvon_blunden:
Outer 0
Inner 0
  Inner 1
Outer 1
  Inner 0
  Inner 1
Outer 2
  Inner 0
  Inner 1
And this produces different results for same and different:
    int
        i, j, k;
    k = 0;
    for( i=0; i<5; i++ )
        for( i=0; i<10; i++ )
            k++;
        }//for
    }//for
    Serial.print( "Inner and outer same: k is " ); Serial.println( k );
    k = 0;
    for( j=0; j<5; j++ )
            k++;
        }//for
    }//for
    Serial.print( "Inner and outer different: k is " ); Serial.println( k );
}//setup
Result:
Inner and outer same: k is 10
Inner and outer different: k is 50
In this case the processor never leaves the loop:
    k = 0;
        for( i=0; i<2; i++ )
            k++;
        }//for
    }//for
This is bad practice that will more often than not produced unexpected results. It shouldn't be encouraged because of an anecdotal case where it did work by chance.
Blackfin:
The scopes are coded differently though. The one in this thread (and my test case, although I apologise for not posting my code, going off this thread's original) ints the variables in the fors, yours ints them in setup. I need more coffee but suspect that may be significant. Really cba to check further right now.
elvon_blunden:
You're right: coded as for( int i=0; ...) things turn out okay. My mistake.
Still think it's a bad idea and bad form though :slight_smile:
Blackfin:
Totally agree: asking for shit.
