Can someone please point me in the right direction as I just can’t get my head around my problem. I have three led’s in an array and want to blink these led’s randomly (just one led lit at a time) without using delay, I have tried to adapt the “blink without delay” example and just can’t get it to run properly. So any guidance on how to remove the delay from my posted sketch will be very welcome.
int LEDpins[] = { 3, 4, 5 };
int time = 100;
int j;
for (int i = 0; i < LEDpins[i]; i++)
pinMode(LEDpins[i], OUTPUT);
void loop(){
j = random(3);
digitalWrite(LEDpins[j], HIGH);
delay(time);
digitalWrite(LEDpins[j], LOW);
delay(time);
Does not what you want. Now you loop from 0 to some random numer because you overflow the array. Use:
for (int i = 0; i < sizeof(LEDpins)/sizeof(LEDpins[0]); i++)
Or make ledpins a byte and skip the “/sizeof(LEDpins[0])”
Give the random a random seed. Otherwise it will be random be the same every time you start the arduino
Fix the indentation, the code is all over. Press ctrl+T
I changed the code a bit, now it show be a bit easier to use blink without delay
const byte LedPins[] = { 3, 4, 5 }; //cammel case is preferred
int time = 100;
//int j; //no need to be global. Also, a single character variable NEVER has a reason to be global
for (byte i = 0; i < sizeof(LedPins); i++)
pinMode(LedPins[i], OUTPUT);
void loop(){
byte j = random(3);
for (byte i = 0; i < sizeof(LedPins); i++){
digitalWrite(LedPins[i], i == j);
delay(time);
My apologies for late reply as I was out of town due to work commitments. I have tried to implement “septillion” suggestion and have had success of sorts with my code posted below. It blinks one led at a time with just one led on at any given moment. However the interval between blinks is not consistent. Although this is not important to my project i would like to know the reason why this is happening. Thank you all for your help.
unsigned long previousMillis = 0;
const long interval = 250;
for (byte i = 0; i < 3; i++)
Serial.print("Start new sequence");
randomSeed(analogRead(A0));
byte randomnumber = random(3);
Serial.print("The random number is = ");
Serial.println(randomnumber);
if (currentMillis - previousMillis >= interval) {
//previousMillis = currentMillis;
for (byte i = 0; i < 3; i++) {
digitalWrite(LedPins[i], i == randomnumber );//, !digitalRead(LedPins[i]);
Remove the serial prints or put them inside the if() statement so it isn't spewing out text thousands of times per second.
For more precise timing, add the interval to previousMillis instead of the current time. This is only a tiny error. You won't detect any timing differences just by looking at it.
Can someone please point me in the right direction as I just can't get my head around my problem. I have three led's in an array and want to blink these led's randomly (just one led lit at a time) without using delay, I have tried to adapt the "blink without delay" example and just can't get it to run properly. So any guidance on how to remove the delay from my posted sketch will be very welcome.
loop() {
if no led is on, and it's time to turn one on
pick an LED at random
turn it on
make note of the fact that a LED is now on
make note of the time
make note of which LED go turned on
if an led is on, and it's time to turn it off
turn it off (using the note we made earlier)
make note of the fact that all the LEDs are now off
make note of the time it got turned off
In order to make note of a fact so that the next iteration of loop() can remember it, it needs to be put in a global or static variable.
