Led blink (no blink) problem??!!!
Nothing else on the board, just: (new components wokring well, no damaged) Led: Green 3mm Pins: Digital pin 3 Digital pin 1 Code:
const int GNDLed = 3;
const int GLed2 = 1;
pinMode(GNDLed, OUTPUT);
pinMode(GLed2, OUTPUT);
void loop(){
digitalWrite(GNDLed, LOW);
digitalWrite(GLed2, HIGH);
/* or Blink
digitalWrite(GLed2, LOW);
Any ideas why it doesn't blink? (light up, because that's what the code does) Is this because of the TX function of the pin?
Not a good idea to use pin 1 as it is used by hardware Serial.
Yea but doesn’t all Digital pins suppose to work as the others? I mean I don’t use serial, i want to blink a led why shouldn’t it work?
How is the LED connected ? Does the LED have a series resistor ?
Don't you understand from the code how the led is connected? yes the led got a resistor
Domino60: Don't you understand from the code how the led is connected?
I understand from the code how it should be connected. But you say it doesn't work so I think maybe you got the led in backwards. Because if you have this code and the led connected right it would blink.
I understand that you understand but believe me i got the led in the right position soldered on a circuit :D i solved the problem by using other pin.. but i use the pin D0 which is RX and its working well, if i use it for let and maybe use serial will that affect my pin ?
No. It is impossible to tell from the code how the LED is connected.
Can I ask why you connected the LED to 2 pins to provide 5V and 0V and did not permanently connect the cathode to GND and the anode to an Arduino pin, with a resistor in the circuit, of course.
I got a led matrix, the only led that it's not working is the one connected to Digital pin 1 (TX)
Says it all really.
Says it all really.
there is nothing to say :D the topic is about a led that doesn't work on the digital pin 1,
