LED blink speed with numbers between 1-255
Hy!
I have made a Code for LED blink speed manipulating with Potentiometer. The blinking started only if I send "start" command and will end if I send "stop".
And now i would like this controlling with numbers 1-255 achieve. How can i send any numbers via Serial(not only 0-9)?
int led=13;
int potpin=5;
byte ch;
String stringone,stringtwo,stringin;
int speedszam;
pinMode(led,OUTPUT);
stringone= String("start");
stringtwo= String("stop");
speedszam= analogRead(potpin);
ch=0;
stringin='\0';
while (Serial.available())
ch=Serial.read();
stringin+=(char)ch;
delay(1);
if (stringin==stringone)
while(stringin != stringtwo)
digitalWrite(led,HIGH);
delay(speedszam);
digitalWrite(led,LOW);
delay(speedszam);
ch=0;
stringin='\0';
ch=Serial.read();
stringin+=(char)ch;
delay(1);
The same way you type them in the serial monitor - one digit at a time. Of course, you'll need some kind of end of packet marker to tell you when you can stop reading. This particular topic only comes up about 8 or 10 times a day.
Things will be much easier if you use a single character for stop and start - for example 's' and 'e' (for end). Don't waste resources sending irrelevant data.
...R
And don't waste resources on Strings, either.
