LED Blink with toggle RF Remote
Hey Guys,
Spent a couple weeks on this code already. New to arduino but have basic programming understanding. Issues I am having is that I have to push the on/off button twice for the led to start working only the first time. Second issue is when I want to turn off buttonC, it will leave the LED on or off depending on where it happens to stop in the loop. I need to be able to make sure the LED always turns off but doesn't affect any of the other buttons. I am manipulating 1 LED with multiple buttons.
const int ledPin1 = 12;
const int buttonA = 9;
const int buttonB = 10;
const int buttonC = 11;
int state = LOW;
int flashStateA = LOW;
int flashStateB = LOW;
int flashStateC = LOW;
int lastFlashStateA = LOW;
int lastFlashStateB = LOW;
int flashLedC = LOW;
int flashLedA = LOW;
const int off = 250;
const int on = 500;
long previousMillis = 0;
long interval = 50;
  pinMode(ledPin1, OUTPUT);
  pinMode(buttonA, INPUT);
  pinMode(buttonB, INPUT);
  pinMode(buttonC, INPUT);
 if(digitalRead(buttonC) == HIGH){
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (flashLedC == LOW)
      flashLedC = HIGH;
      flashLedC = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin1, flashLedC);
   flashStateA = digitalRead(buttonA);
   if (flashStateA != lastFlashStateA)
    onOff();
    lastFlashStateA = flashStateA;
  flashStateB = digitalRead(buttonB);
   if (flashStateB != lastFlashStateB)
    dblFlash();
    lastFlashStateB = flashStateB;
void onOff() {
  if (flashStateA == LOW)
      flashLedA = HIGH;
      flashLedA = LOW;
    digitalWrite(ledPin1, flashLedA);
void dblFlash() {
  if(digitalRead(ledPin1) == LOW){
    state = HIGH;
    digitalWrite(ledPin1, state);
    delay(on);
    state = LOW;
    delay(off);
    state = HIGH;
    delay(on);
    state = LOW;
    else {
    state = LOW;
    delay(off);
    state = HIGH;
    delay(on);
    state = LOW;
    delay(off);
    state = HIGH;
  if (digitalRead(buttonC) == HIGH)If this line detects that buttonC is pressed then you need an else clause to turn off the LED when it is not pressed.
UKHeliBob:
If I put an else clause then I can never have on/off functionality because every time it runs through the loop and buttonC is LOW then it turns off the LED.
So create a boolean for each button that is true if the LED is flashing due to the corresponding button being pressed and only turn it off when the button input is LOW and is not being flashed by any of the button presses.
Incidentally, what should happen if 2 buttons are pressed ?
I was trying to design the program so that the actual state of the pin doesn't matter to save button clicks otherwise I would have to press buttonB off then on for it to run the double flash function. Two buttons being HIGH doesn't provide any extra functionality for my goal.
Could you please provide a little more explanation, it is not making sense to me. Also any insight on why I have to press buttonA twice for onOff to actually command the led would be appreciated, it worked fine when I was using an external interrupt so I assume there is some logic I do not understand. **If buttonA is HIGH when I reset the Arduino then it works as expected when the first press makes the state go LOW but I guess a little backwards.
There is nothing in the code named on/off button. So, it is difficult to figure out what the problem is in the code.
PaulS:
    onOff();
void onOff() {
      flashLedA = HIGH;
      flashLedA = LOW;
I built this on circuits.io
Uno-Led-Light-Bar
Why not use names like onOffPin, onOffState, etc., so that there is no wondering what the heck buttonA means?
      flashLedC = HIGH;
      flashLedC = LOW;
Or
    flashLedC = !flashLedC;
Less code is easier to maintain.
Do you have the LEDs wired so that HIGH means on?
ButtonA is corresponding to ButtonA on a 4 button RF remote from adafruit. If it will help you help me, i will definitely rename the variables.
Thanks for the code shrink. I implemented it in my code and that piece works.
Tried to make the variable names better.
const int onOffBtn = 9;
const int flashBtn = 10;
const int strobeBtn = 11;
int state = LOW;
int onOffBtnState = LOW;
int flashBtnState = LOW;
int strobeBtnState = LOW;
int lastonOffBtnState = LOW;
int lastFlashBtnState = LOW;
int strobeLed = LOW;
int onOffLed = LOW;
const int on = 500;
long interval = 50;
  pinMode(onOffBtn, INPUT);
  pinMode(flashBtn, INPUT);
  pinMode(strobeBtn, INPUT);
 if(digitalRead(strobeBtn) == HIGH){
    strobeLed = !strobeLed;
    digitalWrite(ledPin1, strobeLed);
   onOffBtnState = digitalRead(onOffBtn);
   if (onOffBtnState != lastonOffBtnState)
    onOff();
    lastonOffBtnState = onOffBtnState;
  flashBtnState = digitalRead(flashBtn);
   if (flashBtnState != lastFlashBtnState)
    dblFlash();
    lastFlashBtnState = flashBtnState;
void onOff() {
  if (onOffBtnState == LOW)
      onOffLed = HIGH;
      onOffLed = LOW;
    digitalWrite(ledPin1, onOffLed);
void dblFlash() {
    state = HIGH;
    delay(on);
    state = LOW;
    delay(off);
    state = HIGH;
    delay(on);
    state = LOW;
    else {
    state = LOW;
    delay(off);
    state = HIGH;
    delay(on);
    state = LOW;
    delay(off);
    state = HIGH;
Found a friend to help me with this code. Fixed/working code below.
int state = LOW;
int lastStrobeBtnState = LOW;
int onOffLed = LOW;
const int on = 500;
long interval = 50;
  lastStrobeBtnState = HIGH;
   if(lastStrobeBtnState == HIGH)
   	if(digitalRead(onOffBtn) == HIGH)
      digitalWrite(ledPin1, HIGH);
      digitalWrite(ledPin1, LOW);
   strobeLed = LOW;
   onOff();
   dblFlash();
void onOff() {
     onOffLed = LOW;
     onOffLed = HIGH;
void dblFlash() {
   state = HIGH;
   delay(on);
   state = LOW;
   delay(off);
   state = HIGH;
   delay(on);
   state = LOW;
   else {
   state = LOW;
   delay(off);
   state = HIGH;
   delay(on);
   state = LOW;
   delay(off);
   state = HIGH;
