LED blinking patterns without DELAY and buttons increasing brightness
I am struggling with adding in another LED into the code as well as being able to change the code to get one led to blink in a specific pattern and another LED to fade
What I have currently
button 1 for turning LED 1 Off and ON
Button 2 to turn up the brightness of LED 1 and button 3 to turn down the brightness of LED 1
Overall I want to achieve;
button 1 for turning LED 1 & 2 off and on,
also, button 1 should be able to cycle through 3 different cases where LED 1 blink in different patterns and LED 2 fades in all of the cases. (ideally, I would like that if you held button 1 down for a long press that it will turn off no matter where it is in the cases - but not sure if that's possible)
and button 2 to turn up the brightness of LED 1 and with button 3 to turn down the brightness of LED 1 (button 2 & 3 do not interact with LED 2)
The code originally belongs to EEEnthusiast which I have been able to add an extra button into (so that I have 3 buttons) as well as more cases for that button. however, My understanding of ardunio and c++ isn’t great as just started learning on Wednesday! I have tried writing the code from scratch using debouncing and blink without delay after going through the basic tutorials and changing them however haven’t been able to get very far! This is the closest I’ve been able to get thanks to EEEnthusiast’s!
Here is my current code. Any help in how I can approve this, any overall advice, or simply, where am I going wrong?
const int numOfInputs = 3;
const int inputPins[numOfInputs] = {2,3,4};
const int outputPin = 10;
int LEDState = 0;
int inputState[numOfInputs];
int lastInputState[numOfInputs] = {LOW,LOW};
bool inputFlags[numOfInputs] = {LOW,LOW};
int inputCounters[numOfInputs];
long lastDebounceTime[numOfInputs] = {0,0};
long debounceDelay = 50;
  for(int i = 0; i < numOfInputs; i++) {
    pinMode(inputPins[i], INPUT);
    digitalWrite(inputPins[i], HIGH); // pull-up 20k
  pinMode(outputPin, OUTPUT);
  setInputFlags();
  resolveInputFlags();
  resolveOutputs();
void setInputFlags() {
    int reading = digitalRead(inputPins[i]);
    if (reading != lastInputState[i]) {
      lastDebounceTime[i] = millis();
    if ((millis() - lastDebounceTime[i]) > debounceDelay) {
      if (reading != inputState[i]) {
        inputState[i] = reading;
        if (inputState[i] == HIGH) {
          inputFlags[i] = HIGH;
    lastInputState[i] = reading;
void resolveInputFlags() {
    if(inputFlags[i] == HIGH) {
      // Input Toggle Logic
      inputCounters[i]++;
      updateLEDState(i);
      printString(i);
      inputFlags[i] = LOW;
void printString(int output) {
      Serial.print("Input ");
      Serial.print(output);
      Serial.print(" was pressed ");
      Serial.print(inputCounters[output]);
      Serial.println(" times.");
void updateLEDState(int input) {
  // input 0 = State 0 and 1
  if(input == 0) {
    if(LEDState == 0) {
      LEDState = 1;
    }else{
      LEDState = 0;
  // input 1 = State 2 to 6
  }else if(input == 1) { // 2,3,4,5,6,2,3,4,5,6,2,
    if(LEDState == 0 || LEDState == 1 || LEDState > 5) {
      LEDState = 2;
    }else{
      LEDState++;
  }else if(input == 2) { // 7,8,9,10,11
    if(LEDState == 0 || LEDState == 1 || LEDState > 10) {
      LEDState = 7;
    }else{
      LEDState++;
void resolveOutputs() {
  switch (LEDState) {
    case 0:
      digitalWrite(outputPin, LOW);
    case 1:
      digitalWrite(outputPin, HIGH);
    case 2:
      analogWrite(outputPin, 30);
    case 3:
      analogWrite(outputPin, 70);
    case 4:
      analogWrite(outputPin, 100);
    case 5:
      analogWrite(outputPin, 155);
    case 6:
      analogWrite(outputPin, 255);
     case 7:
     case 8:
     case 9:
     case 10:
     case 11:
    default:
    break ;
What is not working ?
The code works at the moment but not it doesn't do everything I want its only half way there! When I add another LED I can't seem to get it to work nor can I when I try to make patterns within the cases
Welcome to the forum. It's very rare to see someone post their code in code tags in their first post. Plus 1 karma for that :slight_smile:
I think you need to write a clearer specification. For example you want button 1 to turn an LED on or off, but also cycle through some modes? Will this be from the same button press event? Are you intending on implementing long presses?
You also need to be more descriptive than "it doesn't work". What behaviour does it display when you press buttons? How does that differ from your intended outcome? When you update your code post it in a new post so we can see the changes. DON'T edit your original post as you update your code so that people who read this in the future can see how the code progresses and so that people helping can compare versions.
