I solved my problem, sort of. I was writing to Arduino inside a couple of nested for loops, like so:
for (int i = 0; i < cols; i++) {
// Begin loop for rows
for (int j = 0; j < rows; j++) {
grid*[j].display();*
- grid0num = grid[0][0].value();*
- // myPort.write(grid0num);*
- arduino.analogWrite(ledPin0, grid0num);*
- grid1num = grid[0][1].value();*
- // println(grid1num);*
- // myPort.write(grid1num);*
- arduino.analogWrite(ledPin1, grid1num);*
Once I removed the write to outside the for loop, the performance increased dramatically and I now have LEDs that get brighter/dimmer depending on what the webcam is seeing.
This works fine for 8 LEDs, and only for about 5 minutes, until the Arduino seems to get overwhelmed by data and the LEDs stop responding.
The main problem I'm running in to now is how to create this effect for 64 LEDs. I used 8 PWM pins, and the mega only has 13, so I can't hardwire it.
It's been suggested to me to use shift registers or a CD4067 analog multiplexer, which I suppose means I have to get serial to work.
I'm using the simple dimmer tutorial from the Arduino playground. When I open serial I get a character, but the brightness of the LED does not change.
Here is my code (I know its awful):
import cc.arduino.;
import processing.serial.*;
// Learning Processing
// Daniel Shiffman
// http://www.learningprocessing.com
// Example 13-10: Two-dimensional array of objects
// 2D Array of objects
Cell[][] grid;
int c = 0;
int i = 0;
// Number of columns and rows in the grid
int cols = 8;
int rows = 8;
Arduino arduino;
import processing.video.*;
int videoScale = 8;
Serial myPort;
int inByte;
int ledPin0 = 2;
int ledPin1 = 3;
int ledPin2 = 4;
int ledPin3 = 5;
int ledPin4 = 6;
int ledPin5 = 7;
int ledPin6 = 8;
int ledPin7 = 9;
int ledPin8 = 14;
int ledPin9 = 15;
int ledPin10 = 16;
int grid0num = 0;
int grid1num = 0;
int grid2num = 0;
int grid3num = 0;
int grid4num = 0;
int grid5num = 0;
int grid6num = 0;
int grid7num = 0;
int grid8num = 0;
int grid9num = 0;
int grid10num = 0;
//int cols, rows;
Capture video;
size( 64,64 );
grid = new Cell[cols][rows];
video = new Capture(this,cols,rows,30);
// The counter variables i and j are also the column and row numbers
// In this example, they are used as arguments to the constructor for each object in the grid.
for (int i = 0; i < cols; i ++ ) {
for (int j = 0; j < rows; j ++ ) {
// Initialize each object
grid[i][j] = new Cell(ivideoScale,jvideoScale,videoScale,videoScale,i + j);
//println("available serial ports:");
println(Arduino.list());
myPort = new Serial(this, Serial.list()[1], 9600);
/* arduino = new Arduino(this, Arduino.list()[1], 57600);
arduino.pinMode(ledPin0, arduino.OUTPUT);
arduino.pinMode(ledPin1, arduino.OUTPUT);
arduino.pinMode(ledPin2, arduino.OUTPUT);
arduino.pinMode(ledPin3, arduino.OUTPUT);
arduino.pinMode(ledPin4, arduino.OUTPUT);
arduino.pinMode(ledPin5, arduino.OUTPUT);
arduino.pinMode(ledPin6, arduino.OUTPUT);
arduino.pinMode(ledPin7, arduino.OUTPUT);
arduino.pinMode(ledPin8, arduino.OUTPUT);
arduino.pinMode(ledPin9, arduino.OUTPUT);
arduino.pinMode(ledPin10, arduino.OUTPUT);
void draw() {
//while (myPort.available () > 0) {
//int inByte = myPort.read();
//println(inByte);
//r }
// Read image from the camera
if (video.available()) {
video.read();
video.loadPixels();
// Begin loop for columns
grid[i][j].display();
// arduino.analogWrite(ledPin0, grid0num);
// arduino.analogWrite(ledPin1, grid1num);
grid2num = grid[0][2].value();
// println(grid2num);
// myPort.write(grid2num);
// arduino.analogWrite(ledPin2, grid2num);
grid3num = grid[0][3].value();
// println(grid3num);
//myPort.write(grid3num);
// arduino.analogWrite(ledPin3, grid3num);
grid4num = grid[0][4].value();
//myPort.write(grid4num);
// arduino.analogWrite(ledPin4, grid4num);
grid5num = grid[0][5].value();
//myPort.write(grid5num);
// arduino.analogWrite(ledPin5, grid5num);
grid6num = grid[0][6].value();
//myPort.write(grid6num);
// arduino.analogWrite(ledPin6, grid6num);
grid7num = grid[0][7].value();
//myPort.write(grid7num);
// arduino.analogWrite(ledPin7, grid7num);
grid8num = grid[1][0].value();
//myPort.write(grid8num);
// arduino.analogWrite(ledPin2, grid0num);
grid9num = grid[1][1].value();
// myPort.write(grid9num);
grid10num = grid[1][2].value();
// myPort.write(grid10num);
int grid11num = grid[1][3].value();
myPort.write(grid11num);
int grid12num = grid[1][4].value();
myPort.write(grid12num);
int grid13num = grid[1][5].value();
myPort.write(grid13num);
int grid14num = grid[1][6].value();
myPort.write(grid14num);
int grid15num = grid[1][7].value();
myPort.write(grid15num);
int grid16num = grid[2][0].value();
myPort.write(grid16num);
int grid17num = grid[2][1].value();
myPort.write(grid17num);
int grid18num = grid[2][2].value();
myPort.write(grid18num);
int grid19num = grid[2][3].value();
myPort.write(grid19num);
int grid20num = grid[2][4].value();
myPort.write(grid20num);
int grid21num = grid[2][5].value();
myPort.write(grid21num);
int grid22num = grid[2][6].value();
myPort.write(grid22num);
int grid23num = grid[2][7].value();
myPort.write(grid23num);
int grid24num = grid[3][0].value();
myPort.write(grid24num);
int grid25num = grid[3][1].value();
myPort.write(grid25num);
int grid26num = grid[3][2].value();
myPort.write(grid26num);
int grid27num = grid[3][3].value();
myPort.write(grid27num);
int grid28num = grid[3][4].value();
myPort.write(grid28num);
int grid29num = grid[3][5].value();
myPort.write(grid29num);
int grid30num = grid[3][6].value();
myPort.write(grid30num);
int grid31num = grid[3][7].value();
myPort.write(grid31num);
int grid32num = grid[4][0].value();
myPort.write(grid32num);
int grid33num = grid[4][1].value();
myPort.write(grid33num);
int grid34num = grid[4][2].value();
myPort.write(grid34num);
int grid35num = grid[4][3].value();
myPort.write(grid35num);
int grid36num = grid[4][4].value();
myPort.write(grid36num);
int grid37num = grid[4][5].value();
myPort.write(grid37num);
int grid38num = grid[4][6].value();
myPort.write(grid38num);
int grid39num = grid[4][7].value();
myPort.write(grid39num);
int grid40num = grid[5][0].value();
myPort.write(grid40num);
int grid41num = grid[5][1].value();
myPort.write(grid41num);
int grid42num = grid[5][2].value();
myPort.write(grid42num);
int grid43num = grid[5][3].value();
myPort.write(grid43num);
int grid44num = grid[5][4].value();
myPort.write(grid44num);
int grid45num = grid[5][5].value();
myPort.write(grid45num);
int grid46num = grid[5][6].value();
myPort.write(grid46num);
int grid47num = grid[5][7].value();
myPort.write(grid47num);
int grid48num = grid[6][0].value();
myPort.write(grid48num);
int grid49num = grid[6][1].value();
myPort.write(grid49num);
int grid50num = grid[6][2].value();
myPort.write(grid50num);
int grid51num = grid[6][3].value();
myPort.write(grid51num);
int grid52num = grid[6][4].value();
myPort.write(grid52num);
int grid53num = grid[6][5].value();
myPort.write(grid53num);
int grid54num = grid[6][6].value();
myPort.write(grid54num);
int grid55num = grid[6][7].value();
myPort.write(grid55num);
int grid56num = grid[7][0].value();
myPort.write(grid56num);
int grid57num = grid[7][1].value();
myPort.write(grid57num);
int grid58num = grid[7][2].value();
myPort.write(grid58num);
int grid59num = grid[7][3].value();
myPort.write(grid59num);
int grid60num = grid[7][4].value();
myPort.write(grid60num);
int grid61num = grid[7][5].value();
myPort.write(grid61num);
int grid62num = grid[7][6].value();
myPort.write(grid62num);
int grid63num = grid[7][7].value();
myPort.write(grid63num);
println(grid0num);
// A Cell object
class Cell {
// A cell object knows about its location in the grid as well as its size with the variables x, y, w, h.
float x,y; // x,y location
float w,h; // width and height
// Cell Constructor
Cell(float tempX, float tempY, float tempW, float tempH, float tempAngle) {
x = tempX;
y = tempY;
w = tempW;
h = tempH;
void display() {
int pixelX = int(x)/videoScale;
int pixelY = int(y)/videoScale;
int loc = pixelX+pixelY*video.width;
color c = video.pixels[loc];
float value = brightness(c);
//println(value);
fill(brightness(c));
rect(x,y,w,h);
int value(){
int loc = pixelX+pixelYvideo.width;
int value = int(brightness(c));
return value;
