Thank you, ShapeShifter for the reply. I have check the setup several times for a short. But, I have found none.
The wiring is a wire from pin 8 to the anode of the LED and the cathode of LED is connected to the 470 ohm resistor that goes to ground with another wire. I have only two wires, the resistor and LED connected to the Yun Board. I have confirmed the ground connection does go to ground.
Here is the testLed sketch that I use when the LED lights correctly.
/* single red LED on 8
pinMode(8, OUTPUT);
digitalWrite(8, HIGH);
With this code, I get at pin 8 (Led anode), 4.45 Volts and at the LED cathode/470 resistor connection, 2.51 Volts. The LED has a normal brightness.
Here is the code for the bridge example that I am using:
Arduino Yún Bridge example
This example for the Arduino Yún shows how to use the
Bridge library to access the digital and analog pins
on the board through REST calls. It demonstrates how
you can create your own API when using REST style
calls through the browser.
Possible commands created in this shetch:
* "/arduino/digital/13" -> digitalRead(13)
* "/arduino/digital/13/1" -> digitalWrite(13, HIGH)
* "/arduino/analog/2/123" -> analogWrite(2, 123)
* "/arduino/analog/2" -> analogRead(2)
* "/arduino/mode/13/input" -> pinMode(13, INPUT)
* "/arduino/mode/13/output" -> pinMode(13, OUTPUT)
This example code is part of the public domain
http://arduino.cc/en/Tutorial/Bridge
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
// Listen on default port 5555, the webserver on the Yún
// will forward there all the HTTP requests for us.
YunServer server;
// Bridge startup
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Bridge.begin();
digitalWrite(13, HIGH);
// Listen for incoming connection only from localhost
// (no one from the external network could connect)
server.listenOnLocalhost();
server.begin();
// Get clients coming from server
YunClient client = server.accept();
// There is a new client?
if (client) {
// Process request
process(client);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
void process(YunClient client) {
// read the command
String command = client.readStringUntil('/');
// is "digital" command?
if (command == "digital") {
digitalCommand(client);
// is "analog" command?
if (command == "analog") {
analogCommand(client);
// is "mode" command?
if (command == "mode") {
modeCommand(client);
void digitalCommand(YunClient client) {
int pin, value;
// Read pin number
pin = client.parseInt();
// If the next character is a '/' it means we have an URL
// with a value like: "/digital/13/1"
if (client.read() == '/') {
value = client.parseInt();
digitalWrite(pin, value);
else {
value = digitalRead(pin);
// Send feedback to client
client.print(F("Pin D"));
client.print(pin);
client.print(F(" set to "));
client.println(value);
// Update datastore key with the current pin value
String key = "D";
key += pin;
Bridge.put(key, String(value));
void analogCommand(YunClient client) {
int pin, value;
// Read pin number
// with a value like: "/analog/5/120"
// Read value and execute command
analogWrite(pin, value);
client.print(pin);
client.print(F(" set to analog "));
String key = "D";
key += pin;
else {
// Read analog pin
value = analogRead(pin);
client.print(F("Pin A"));
client.print(pin);
client.print(F(" reads analog "));
String key = "A";
key += pin;
void modeCommand(YunClient client) {
int pin;
// Read pin number
// If the next character is not a '/' we have a malformed URL
if (client.read() != '/') {
client.println(F("error"));
return;
String mode = client.readStringUntil('\r');
if (mode == "input") {
pinMode(pin, INPUT);
client.print(pin);
client.print(F(" configured as INPUT!"));
return;
if (mode == "output") {
pinMode(pin, OUTPUT);
client.print(pin);
client.print(F(" configured as OUTPUT!"));
return;
client.print(F("error: invalid mode "));
client.print(mode);
When I use this code with REST command for pin 8 on (arduino.local/arduino/digital/8/1), get the lower value of 1.74 Volts at the pin 8 LED anode connection. The LED cathode resistor connection is 38 millivolts.
There are no other connections to the board other than the USB power. I decided to turn on all the pins from 8 to 13 "on". Pins 8, 9, 10, 11, and 12 all produced the low LED light output when the LED is connected to them. However, with a pin 13 connection, the LED has normal brightness along with the board L13 device. There is no problem turning on or off a pin.
I am open to trying any suggestions. Thanks in advance for any help.
