led brightness
Hello,
/* Blink Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain. */
// Pin 13 has an LED connected on most Arduino boards. // give it a name: int led = 13; int led1 = 12;
// the setup routine runs once when you press reset: void setup() { // initialize the digital pin as an output. pinMode(led, OUTPUT); }
// the loop routine runs over and over again forever: void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) digitalWrite(led1, HIGH); delay(1000); // wait for a second digitalWrite(led, LOW); digitalWrite(led1, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second }
this is the normal blink sketch with one led more. there is in normal blue led connectet from pin 12 to gnd.
When i first put led13 high in the code the blue led is not so bright like when i fist put led12 high. What is the problem? Why will the LED on pin 12 not have the same brightness?
There's something missing here:
Hint: you have two pins..... 8)
Once you fix that, the LED brightness will also vary with the current limit resistor used, and the mcd rating of the LED.
:D:D i need a break ;)
Sometimes it does come down to that 8)
