I am completely new to Arduino and am currently working through the booklet. I am rather stuck on one exercise at the end of Project 5.
It says that I should tweak only the last few lines of the code so the LEDs do not bounce forward and back, but instead restart each time it reaches the end. Everything I try seems to make the LEDs do strange things.
There was a topic on this forum I saw but it didn’t help much, as the answers on there changed the code significantly. I also did not understand much because I am a beginner at this. Is there any way to do this as it says in the book?
// Project 5 - LED Chase Effect
// Create array for LED pins
byte ledPin[] = {4, 5, 6, 7, 8, 9, 10, 11, 12, 13};
int ledDelay(65); // time delay between changes
int direction = 1;
int currentLED = 0;
unsigned long changeTime;
// set all pins to output
for (int x=0; x<10; x++) {
pinMode(ledPin[x], OUTPUT); }
changeTime = millis();
// if it has been ledDelay ms since last change
if ((millis() - changeTime) > ledDelay) {
changeLED();
void changeLED() {
// turn off all LED's
digitalWrite(ledPin[x], LOW);
// turn on the current LED
digitalWrite(ledPin[currentLED], HIGH);
// increment by the direction value
currentLED += direction;
// change direction if we reach the end
if (currentLED == 9) {direction = -1;}
if (currentLED == 0) {direction = 1;} }
I did want to solve it myself, but I just end up getting annoyed with it and getting no where in the end.
direction = -1;
direction = 1;
These are the lines of code that test whether the current LED is at the end of the line and if so change the increment so that the effect is to bounce the lit LED backward and forward
If you were to change
direction = -1;
so that instead of changing the increment it put the current LED number back to zero, I wonder what would happen ? If you did that then the test for the current LED being zero and the change of direction to 1 would not be needed because direction would already equal 1.
direction = -1;
direction = 1;
direction = -1;
Brilliant thanks, that worked. I had tried something similar but was coding it wrong in some way - it makes alot of sense now with your explanation.
