LED Chaser sketch won't compile after update to Arduino 1.6.5
A sketch that was working on version 1.0.5 of the Arduino IDE will no longer compile on version 1.6.5.
I'm pretty new to this programming/Arduino thing, but it looks like the problem has to do with a library I'd added to simplify chasing LEDs.
The sketch drives servos for the wings of a PKE meter prop (from Ghostbusters} and chases the LEDs on the wings and display.
#include <Servo.h>
#include <ChaseLEDs.h>
#define NACELLE_RATE         22    // Analog input for reading the nacelle chase rate
#define NACELLE_CHASE_LEN    8     // Length of nacelle chase, 1..6
#define NACELLE_MIN_PERIOD   25    // Minimum time to advance the nacelle chase (milliseconds)
#define NACELLE_MAX_PERIOD   250   // Maximum time to advance the nacelle chase (milliseconds)
#define NACELLE_DIM_VALUE    0      // Value for dimming previous LED in chase, 0..255
// Output pins to use for the nacelle chase
boolean chaseOn = false;
byte nacelleChasePins[8] = {14, 15, 16, 17, 18, 19, 20, 21}; // Pin 21 is not connected to leave blank spot in sequence
class NacelleChaseLEDs : public ChaseLEDs
public:
  NacelleChaseLEDs(const byte *pins, int num)
    : ChaseLEDs(pins, num, 0) {}
protected:
  void advance(byte prevPin, byte nextPin) {
    digitalWrite(previousPin(2), LOW);
    analogWrite(prevPin, NACELLE_DIM_VALUE);
    if (chaseOn)
    digitalWrite(nextPin, HIGH);
    setAdvanceTime(map(analogRead(NACELLE_RATE), 0, 1023, NACELLE_MIN_PERIOD, NACELLE_MAX_PERIOD));
    //digitalWrite(13, !digitalRead(13)); // toggle the LED  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
NacelleChaseLEDs nacelleChase(nacelleChasePins, NACELLE_CHASE_LEN);
const int touchPinFull = 12;     // the number of the pushbutton pin
int touchStateFull = 0;
Servo myservoL;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
Servo myservoR;
  myservoL.attach(9);
  myservoR.attach(10);
  digitalWrite(13, LOW); //Status LED OFF
  pinMode(14, OUTPUT);  //Wing LED
  pinMode(15, OUTPUT);  //Wing LED
  pinMode(16, OUTPUT);  //Wing LED
  pinMode(17, OUTPUT);  //Wing LED
  pinMode(18, OUTPUT);  //Wing LED
  pinMode(19, OUTPUT);  //Wing LED
  pinMode(20, OUTPUT);  //Wing LED
  pinMode(13, OUTPUT);       // Status LED
  pinMode(touchPinFull, INPUT);
  pinMode(11, INPUT_PULLUP); // Pushbutton
{touchStateFull = digitalRead(touchPinFull);
  if (touchStateFull==LOW) // 12 pin is low due to pullup resistor - Returns 0, so this block happens.  If it returns 1 (touch pressed, pin goes high), else (Full Wings) happens  WINGS AT HOME, NO LIGHTS
    if (digitalRead(11)) // 11 pin is high due to pullup resistor - Returns 1, so this block happens.  If it returns 0 (button pressed, pin goes low), else happens  WINGS AT HOME, NO LIGHTS
    digitalWrite(14, LOW);  //Wing LED OFF
    digitalWrite(15, LOW);  //Wing LED OFF
    digitalWrite(16, LOW);  //Wing LED OFF
    digitalWrite(17, LOW);  //Wing LED OFF
    digitalWrite(18, LOW);  //Wing LED OFF
    digitalWrite(19, LOW);  //Wing LED OFF
    digitalWrite(20, LOW);  //Wing LED OFF
    myservoL.write(20);   // Servo home position
    myservoR.write(140);  // Servo home position
    chaseOn = false;
    // Pin is Low - returns 0 - 12 pin is low due to pushbutton pressed  WINGS HALF UP, LIGHTS
    digitalWrite(13, HIGH);  // Status LED on
    myservoL.write(80);  // Servo half up
    myservoR.write(80);  // Servo half up
    chaseOn = true;
    // Pin is High - returns 1 - 12 pin is high due to touch pressed  WINGS FULL UP, LIGHTS
    myservoL.write(140); // Servo Full Up
    myservoR.write(20);  // Servo Full Up
    chaseOn = true;
  nacelleChase.loop();
This was all working fine, but I had to update my Teensy 3.x libraries to play audio from an SD card, and that required updating the Arduino software.
After the update, when I attempt to compile this I get this error message (I've removed much of the error due to forum limitations):
Arduino: 1.6.5 (Mac OS X), TD: 1.25, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimized (overclock), US English"
In file included from Pushbutton_Dual_Servos_With_Chase_Blink.ino:2:0:
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:1:5: error: stray '\302' in program
1 /*
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:1:5: error: stray '\240' in program
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:22:4: error: stray '\302' in program
22
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:22:4: error: stray '\240' in program
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:23:4: error: stray '\302' in program
23 #ifndef ChaseLEDs_h
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:23:4: error: stray '\240' in program
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:23:8: error: stray '#' in program
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:24:4: error: stray '\302' in program
24 #define ChaseLEDs_h
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:24:4: error: stray '\240' in program
/Users/ShawnM/Documents/Arduino/libraries/ChaseLEDs/ChaseLEDs.h:24:8: error: stray '#' in program
Error compiling.
** This report would have more information with**
** "Show verbose output during compilation"**
** enabled in File > Preferences.**
I assume something's broken with the ChaseLEDs library, but I don't know what. The ChaseLEDs library is visible in the "Contributed libraries" section in the "Include Library" pulldown. If I start a new sketch, add the ChaseLEDs library, and then attempt to compile I get the same error message.
This is the ChaseLEDs.h code (with copyright info removed):
1 /*
   22
   25
   26 #include <inttypes.h>
   27
   28 class ChaseLEDs
   29 {
   30 public:
   31     ChaseLEDs(const uint8_t *pins, int num, unsigned long advanceTime);
   32
   33     void loop();
   34
   35     unsigned long advanceTime() const { return _advanceTime; }
   36     void setAdvanceTime(unsigned long advanceTime) { _advanceTime = advanceTime; }
   37
   38 protected:
   39     virtual void advance(uint8_t prevPin, uint8_t nextPin);
   40     uint8_t previousPin(int n) const
   41         { return _pins[(_currentIndex + _numPins - n) % _numPins]; }
   42
   43 private:
   44     const uint8_t *_pins;
   45     int _numPins;
   46     int _currentIndex;
   47     unsigned long _advanceTime;
   48     unsigned long _lastChange;
   49 };
   50
   51 #endif
This is the code for ChaseLEDs.cpp:
   1 /*
   22
   23 #include "ChaseLEDs.h"
   24 #if defined(ARDUINO) && ARDUINO >= 100
   25 #include <Arduino.h>
   26 #else
   27 #include <WProgram.h>
   28 #endif
   29
   71 ChaseLEDs::ChaseLEDs(const uint8_t *pins, int num, unsigned long advanceTime)
   72     : _pins(pins)
   73     , _numPins(num)
   74     , _currentIndex(-1)
   75     , _advanceTime(advanceTime)
   76     , _lastChange(millis())
   77 {
   78     for (uint8_t index = 0; index < _numPins; ++index) {
   79         pinMode(_pins[index], OUTPUT);
   80         digitalWrite(_pins[index], LOW);
   81     }
   82 }
   83
   87 void ChaseLEDs::loop()
   88 {
   89     if (_currentIndex >= 0) {
   90         if ((millis() - _lastChange) >= _advanceTime) {
   91             // Advance to the next LED in sequence.
   92             _currentIndex = (_currentIndex + 1) % _numPins;
   93             _lastChange += _advanceTime;
   94             advance(previousPin(1), _pins[_currentIndex]);
   95         }
   96     } else {
   97         // First time - light the first LED.
   98         _currentIndex = 0;
   99         _lastChange = millis();
  100         advance(previousPin(1), _pins[_currentIndex]);
  101     }
  102 }
  103
  136 void ChaseLEDs::advance(uint8_t prevPin, uint8_t nextPin)
  137 {
  138     digitalWrite(prevPin, LOW);
  139     digitalWrite(nextPin, HIGH);
  140 }
  141
This is the basis for the ChaseLEDs library I'm using:
http://rweather.github.io/arduinolibs/blink_startrek.html
Any help would be appreciated.
Thank you.
Shawn Marshall
Portland, OR
You need to post the code you are trying to compile, too.
Thanks for the reply.
The code I'm attempting to compile IS there. It's the first block of code in my post.
As I wrote, just creating a new sketch and adding the ChaseLEDs library (with nothing else) creates the same compiling error.
Shawn
I think your library files are munged. My guess would be you saved them direct from github, and they've got the line numbers and crap (for human readability) still in them
Thanks for the reply. I guess it could be the line numbers. I'm fuzzy as to why that library worked with the earlier version of Arduino but not 1.6.5.
Cheers.
Shawn
Assuming this is the actual code you are using and not some erroneous "cut and paste"
1 /*          [b]THIS IS THE ERROR LINE [b][/b][/b]
combination of (line number) "1"  and orphaned  - missing closing */
Just delete it all.
Or just delete "1" and see what the compiler will say about no ending comment.
   22
   25
   27
   28 class ChaseLEDs
   29 {
   30 public:
   32
   33     void loop();
   34
   37
   38 protected:
   42
   43 private:
   45     int _numPins;
   49 };
   50
   51 #endif
If you select "display line numbers " in preferences the compiler will work fine with lines in editor.
And if you use "AutoFormat" it sometime identifies mismatched pairs ( /* ... no */, { ... no ending bracket ) , but not always.
It looks like the line numbers were the culprit. Not sure what changed between then and now, but things look okay now. Maybe that preference changed.
Thanks for the help, I appreciate it.
Shawn
I gave up on trying to figure out how to download a copy of the BlinkLED and ChaseLED libraries from the site you posted the URL to (not a link, which would have been better).
It appears that the code you have was copied from a web site and pasted into a file, and that some web characters, like dashes, have different ASCII values than some code characters, like minus signs.
