Hey all...
I am new to Arduino and its software and while learning to use 'int' to avoid having to write the 'pinMode' thing for every single LED on my VU meter, I accidently created an LED chaser that works really well. But I can't understand how it worked. So it would be really nice if someone could look at my code and write a bit about it.
int pins[5] = {2,3,4,5,6};
for (int i=0; i<5; i++) {
pinMode(pins*, OUTPUT);*
- for (int i=0; i<5; i++) {*
_ digitalWrite(pins*, 1);_
_ delay(50);_
_ digitalWrite(pins, 0);
delay(50);
It turns the LEDs on the pins 2-6 one-by-one according to the delay I set.
I originally wanted all the LEDs to blink for a test and wrote this thing hoping not to write 'pinMode' to all my 12 LEDs of my VU Meter._
digitalWrite(pins, 1);
delay(50);
delay(50);
Turns on the LED on the first pin
Turns the same LED off after the delay
Then i increases by 1 and the process repeats for the next LED.
Added comments
int pins[5] = {2, 3, 4, 5, 6}; //array of pins with LEDs
for (int i = 0; i < 5; i++) //should be 4 not 5
pinMode(pins, OUTPUT);
for (int i = 0; i < 5; i++) //a counter from 0 to 5 - should be from 0 to 4
digitalWrite(pins[i], 1); //turn the the current pin HIGH
delay(50); //wait a bit
digitalWrite(pins[i], 0); /turn teh current pin LOW
} //now do it over again
Note that you have 5 pin numbers in the array numbered 0 to 4 but your for loop uses 0 to 5
If you want all of the LEDs to flash at the same time then turn them all on, wait a bit, turn them off and wait a bit. Do not wait between changing the state of each LED
Compare with :
delay(50);
delay(50);
Regards,
bidouilleelec
UKHeliBob:
Added comments
No UKHeliBob, if I change it to 4, then the last LED will be skipped and the rest will keep on chasing.
Hello UKHeliBob
UKHeliBob:
Added comments
"Note that you have 5 pin numbers in the array numbered 0 to 4 but your for loop uses 0 to 5"
Regards,
bidouilleelec
Sorry for any confusion.
I am, of course wrong about the limit needing to be 4 rather than 5
May I know the best way to select many pins as an OUTPUT or INPUT without 'pinMode'ing every one of them?
Sangeeth_Satheesh:
See Port Manipulation but note that all the pins being manipulated must be on the same port
UKHeliBob:
Ah..! isn't there any simple way for doing it.
Also, my pins do not blong to the same register.
A for loop iterating through an array of pins is the neatest way.
NOTE : pins default to INPUT so you never actually need to set the pinMode() for input pins unless you want to use INPUT_PULLUP
UKHeliBob:
Sorry, I didn't understand that.
Could you make it clear please...
Have a look at LED exercise which is a similar but slightly different question to yours.
Sangeeth_Satheesh:
Sangeeth_Satheesh:
It is exactly what the code in the original post of this thread does
OK, so I just want to blink all the 5 LEDs together.
Could anybody suggest a suitable code for me?
