Hi
Thanks for looking into this topic..
I have a fairly simple code (attached)... basically, what I need is to input a photosensor which will dictate whether the code below runs or not (the code, not just the LEDs - there will be many in my project)
So, if its dark, I want the code to run... if its bright, i want it to stay off...
Would anybody have any advice or tips for editing my code?
Thanks
Dara
//CODE
const byte LED01Pin = 13;
// set the LED pins as output:
pinMode(LED01Pin, OUTPUT);
SequenceRun01(LED01Pin);
void SequenceRun01(const byte pin)
const int sequence[][2] =
// For each step, the pin state and duration in milliseconds
{HIGH, 1500},
{LOW, 2500}
// Calculate the number of steps in the sequence
const byte sequenceLength = sizeof sequence / sizeof sequence[0];
// A place to store the start time of the current step
static unsigned long intervalStart = 0; // 0 means DO THE INITIALIZATION
// A place to store the desired duration of the current step
static unsigned long interval;
// An index into the sequence of the current step
static byte index = 0; // (Yes, you can start at any step in the sequence.)
if (intervalStart == 0)
// First time through
digitalWrite(pin, sequence[index][0]);
interval = sequence[index][1]; // How long until the next step
intervalStart = currentMillis; // When this step started
if (currentMillis - intervalStart >= interval)
// The step is over. Go on to the next step
index = (index + 1) % sequenceLength; // '%' is the Modulo (remainder after integer division) operator.
digitalWrite(pin, sequence[index][0]); // Is the step HIGH or LOW
