Hi, I bought and soldered together one of these LED clock kits
http://www.ebay.co.uk/itm/351899968922?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
However, as well as the time it also displays the temperature, date and day of the week every 45 seconds.
This is unnecessary and can be confusing.
I would like it to permanently display the time only.
I guess this would mean reprogramming the ic which I cannot do.
Would it be possible to remove/bypass the ic and connect an arduino to the LED digits to display the time only please?
There is a light sensor that dims the LED's at night.
This works perfectly and is a feature I would like to keep.
Thanks for any help.
If you like to modify the source code of the clock
here is the code
If you like to control by Arduino
here is the example
http://www.qsl.net/v/ve3lny/travel_clock.html
Thanks BillHo,
Are you saying that if I buy a USB-UART adapter I can modify the firmware on the ic?
johnnycox:
Thanks BillHo,Are you saying that if I buy a USB-UART adapter I can modify the firmware on the ic?
Yes, you can modify the firmware on the ic.
