Hello all i got a small problem i found a led clock online Using 46 leds and everything seems to work even the Sketch but nothing in there for push buttons for the Minutes and Hours. Im not good at Coding at all I'm more of a hardware Guy. i really need help the sketch is using the Time.h library Sketch attached can someone please help me. i try to ask a couple of peoples i know hat plays around with arduino's but none of them know how to add this kind of Feature in it.
Im not a programer or a coder at all I'm more of hardware i do not know how to program the pins or what ode to use or anything like that to make the buttons work so when the first button pushed the hours change and when the second button is pushed the minutes are change. as before i can do the hardware but not software i been asking all my friends and peoples i know who is playing with arduinos to help and none of them are doing anything with clocks yet.
honestly man no because i tried to search online for time.h library hour and minute push button it came up alot fo stuff but nothing i can understand it's a little over my head when it comes to this and programing. i checked out a few pages but got so lost.
If you open up the IDE, click on "File", then "Examples", "02.Digital", "DigitalInputPullup" the example code given should be easy for a hardware guy to understand.
It will get you started on how to wire up a switch and read it.
Then you transplant that code into yours.
hello i got one friend to help he doesn't know about the time.h library but he try to help he made some changes to the sketch when i tried it i push the one button that is on pin 13 for the hour the led got dim but when i hit the button that is on pin 12 nothing happens i try to look at it a little more the code but it's to much i include it in attached below.
what do i change it too when i try to do a upload of the sketch with the new minute change i get a error in orange says a function-definition is not allowed here before '{' token and in black says
lite_brite_code.ino: In function 'void loop()':
lite_brite_code:163: error: a function-definition is not allowed here before '{' token
lite_brite_code:712: error: expected `}' at end of input
The numbers in bold below are line numbers. Look at those lines (and/or lines before & after).
Questions to ask yourself-
How does the formatting on those lines differ from similar-looking sections in other areas of the code?
What did I change?
What is before "{"?
....where was the "{" before I changed things?
What does "{" do?
got the clock working with the 2 push buttons but can someone please help me on adding a alarm function please I'm not good at coding can someone please help me to change this i have included the text sketch below.
