LED COLORS
Hello everyone, i'm brand new to Arduino and i would llike to accomplish the following..
i would like to have a button that changes a led color everytime the button is changed (ie:)
pressed 1x = red pressed again = green pressed again = blue pressed again = yellow pressed again = purple pressed again = orange
if pressed again = red (basically starting from the beginning).. how many colors are in an led (not talking about the single color led bulbs)..
i seen a tetris table on you tube that had all colors as well as a visualizer coffee table.. so, i want to know how to control colors.
thanks in advance, Ruffsta
Hi Ruffsta,
Have a look at this Instructable which looks like it will answer a lot of your questions.
HTH,
Jim
Pick yourself up an RGB LED do some playing. Red, no green, no blue = Red no red, Green, no blue = Green no red, no green, Blue = Blue all three = White Red, no green, Blue = Purple Red, Green, no blue = Amber (sort of yellow) Orange - Idon't know. If you had PWM on each color, then you change the intensity of the mixed colors as well. Say 75% red, 25% green, no blue = Orange(ish)?
So if you had an arduino, an RGB LED, 3 current limit resistors sized to not exceed the current capabiliy of the 3 LEDs (since Red, Green, Blue typically have different forward voltages, different current limit resistors would be needed), then connecting each to a PWM pin and using analogWrite (RedLedPin, 196); // 0 min, 255 max analogWrite (GreenLedPin, 64); analogWrite (BlueLedPin, 0); mighe yield orange for example. Have to experiment some and see.
From there, you expand on the hardware for the size table you need, maybe with tons of chips (all LEDs capable of being driven all the time), maybe with multiplxing (one, or maybe a row or a column, are on at one time, but you switch between them all quickly to trick the eye into seeing them all as on, but maybe not quite as bright - but high brightness LEDs (blindingly bright even) can overcome that too).
Colorpic is a useful tool to see what RGB mix you need to get what colour.
thank you very much guys.. (as for the color picker.. i code websites and already have one, but thanks tho).
i love the fast responses, i thought i was going to be waiting a few days for an answer.
Ruffsta: i thought i was going to be waiting a few days for an answer.
The beauty of time zones on the Internet, is that there's always someone, somewhere reading the forum!
