Hello
I want to connect 20 hexagons (nanoleaf like) but I need 12 pins on each side of the hexagon.
What kind of connectors to use? Or guide me to a cheap and good connection between hexagons.
Thank you
boolrules:
They will have to be inserted/removed in the vertical plane?
Solar Roadways model?
Yes they are inserted/removed in the vertical plane...first tile it is connected to a motherboard that send different signals each pin. The main idea is to send all 12 connections between tiles.
They are ok but the main problem is that is hard to solder 10 0000 tiles for mass production.....I want something similar to laptop connections like ribbon connections ...Thank you for the quick reply
I need to send all the connections through all the hexagons....for example one hexagon is red and use ground and pin 1, another hex is blue and use ground and pin 6 an so on...
