My background on electronics is very limited.
What are my options here? Is the circuit from instructables supposed to work for my situation, or not?
I don’t want to blow up anything
I’m looking into PWM controlling it with an arduino (or esp8266 like the wemos d1 mini if possible)
If your power source is truly a current source, then the instructable method should work.
CAUTION: If it isn't a current source, but a regular power supply, you will destroy the wall plug, the transistor, and possibly anyone close to the wall plug.
For safety: Try the circuit in the instructable, but with one addition: put a 1A fuse between the MOSFET drain and the positive terminal of the supply.
So... I finally got everything in.
But there's a problem. I built the circuit in the schematic with a 1amp fuse like you recommended.
When I connect the source with the drain disconnected, the lex'slightlight, which they should because the shunt is disconnected.
But as soon as I connect the mosfet drain (no pwm signal connected to the gate) the power source starts making a high frequency noise and after a few seconds the fuse blows.
The mosfet also becomes very hot. Is it normal it's shunting even without a pwm signal connected?
So this means the power supply can not handle being shorted?
Is it best to build a source my own, or buy something else that can be dimmed
The led bar specs say:
36w
38vdc, 900ma
With the gate not connected it floats and picks up interference. This results in it turning on and off rapidly and not very fully. You should have a 10K resistor from gate to source to prevent this.
That being said it sounds like you do not have a constant current supply so you might want to try a chopper circuit rather than a shunt. But measure the voltage of your supply both with the LEDs connected and with not. That will tell you what sort of power supply you have.
It is that circuit, but with the ground of the LEDs connected to the drain of the FET instead of the ground. So that when the FET turns on there is current through the LEDs. Still have that 10K between the gate and ground.
Unfortunately that destructibles works by shunting the supply current around the LEDs, hence turning them OFF under PWM.
This means the current source doesn't see an open circuit load and go mental.
Unfortunately it ASSUMES the current source is ISOLATED from the POWER MAINS.
As has already been pointed out, no 10K between gate and source to protect open circuit gate.
Yeah i'm not using that IRF840 actually. I did look that up and am using a irlz24n, which is a logic level mosfet.
So now i built the new circuit. I tested it with the LED's not connected, i put my voltmeter in place and have now 2 dead MOSFETs.
Is this because i put my voltmeter where the LED's should be? Or another reason?
Initially i had about 35V there, when it died i have 46V. Which is the voltage when measuring the source with no load.
I did change the mosfet again and attached the led’s. It seems to work now BUT…
When i start a fade (from 0 to 255) everything low just flickers enormously (like a strobe).
When i pass ± 180 it starts to dim nicely. When it flickers, i hear a noise in the source also.
Thanks for the pics.
Can you check your protoboard and make sure the power rails down each side are connected and not broken where I have indicated?
That 10K might not be connected to gnd.
What other components have you got connected in the picture?
I would suggest your gnd connection to the MOSFET from the Arduino controller NOT daisy change through the RF unit, but connect directly to the Arduino.
Thanks… Tom…
I have an ESP8266 (wemos d1 mini) as the microcontroller, connected to a pca9685 breakout board for the pwm signal.
There’s also a i2c lcd and a onewire sensor, but that’s of no importance
I have attached a new pic where i removed the sensor. Just to remove the mess a bit.
I am really stupid, the breadboard power lines are indeed broken up. Djeezes…
I connected to the ground line so the resistor is connected.
However i now have another dead mosfet. One to go
EDIT: Sorry… don’t know what i did but my mosfet ain’t dead… Also the resistor wasn’t 10k but 220ohm.
Got mixed up somewhere. Stupid mistakes.
I changed to a 10k but result is the same.
Yes the protoboard link problem is not indicated on the boards, some do have a link others don't.
When i pass +- 180 it starts to dim nicely. When it flickers, i hear a noise in the source also.
This could be due to the PWM frequency.
The reason that using PWM to control the LED brightness with the a constant current source is that the source also uses PWM to give constant current.
I don't know, but can you change the PWM frequency off you control PWM.
One PWM frequency may be a frequency harmonic of the other and at certain PWM % various harmonic components may cause problems.
I don't think the flickering is related to the pwm frequency.
When i change the frequency to 40 i can see flickering in the higher ranges also.
But in the lower range it more flashing and n between i can see the same low hz flicker.
I think it's the power supply not handling the pwm very good. Would a capacitor over the led + - be a good option?
Like mentioned in this post :
I however don't have one here, perhaps i can recover one from an old device somewhere...
I also tryed the esp8266's own pwm, same result.
I have a video here:
Once it turns on it does keep dimming but it's too bright in the video to notice.
I have a transformer from 230V to 12Vdc.
I would then like to use kbl005 to rectifie and a lm7810 to have 10VDC in parallel with a lm7805 to have 5VDC.
This way i can power everything from the 230V mains supply.
Can i use my irlz24n to step up the pwm like shown in the diagram i drew?
