LED Control
What is the best way to control multiple status LED's from Ardunio Without using the Pin's Power?
ok I found this I think it works right I will just use a huge PCB and alot of transistors http://www.arduino.cc/playground/uploads/Learning/relays.pdf
You didn't explain much, what is multiple status of LED? How many LEDs ? Single color or RGB? What spec or link to LEDS? etc., it all depends.
Could also just hook up a few shift registers, let their outputs turn the LEDs on/off. Lot easier than relays.
