LED Cube
Does anybody know where I can get code for a 4x4x4 LED Cube. I am not a member of instructables.
post a link to the guide on instructables you want and i will download and send you the pdf
I already got those files. I would prefer to have some others or at least a editor that will generate the code for me.
i thought you said you were not a member
I just "searched" google for that file name and it popped up with the file.
well, I now need this file but I cannot find it anywhere. Will someone please download this for me and send me the files, thanks.
http://www.instructables.com/id/The-4x4x4-LED-cube-Arduino/step5/PROGRAM/
Have you seen the Rainbowduino cube which is 4x4x4? I have one and my teenagage daughter uses it as a night lite. It runs the "plasma" code for the Rainbowduino which cycles through many different colors. It was pretty simple to put together but does require a rainbowduino module.
http://www.seeedstudio.com/depot/rainbow-cube-kit-rgb-4x4x4-rainbowduino-compatible-p-596.html?cPath=100
http://www.seeedstudio.com/depot/rainbowduino-led-driver-platform-atmega-328-p-371.html?cPath=163_169
http://www.seeedstudio.com/depot/60mm-square-88-led-matrix-super-bright-rgb-p-113.html?cPath=163_165
That does not help me at all. I already have a cube built and just need the files from that link.
http://www.instructables.com/files/orig/FV8/XM2M/GGPEXFII/FV8XM2MGGPEXFII.zip
I hope this works^^
Thanks!
