LED Dice (multiple)
I want to work on a more advanced project and want to expand on the led dice project (six LED's randomly light up to represent a number). I was wondering if you think that this project would be possible.
Have two random number generators output to two sets of three LED's (I do not want to use the 7 segment displays) and then have one of two LED's light up to show which side had the higher number. So essentially it would act like rock-paper-scissors.
Any ideas or suggestions are appreciated. Is this even possible?
Yes perfectly possible.
Why not have two proper patterned dice ( using 7 LEDs per dice ).
Use two shift registers for getting the outputs and use an array for a look up table for the pattern to display.
You only need 4 outputs for a 7LED dice face because opposite lights are always on together:
Face:
a b
cde
f g
One:
.o.
Two:
o .
. o
Three:
o .
.o.
. o
Four:
o o
o o
Five
o o
.o.
o o
Six:
o o
o.o
o o
So a=g, b=f, and c=e.
Also it is fairly simple logic to convert numbers to a dice face:
In|abcd
 1|0001
 2|1000
 3|1001
 4|1100
 5|1101
 6|1110
