LED diode controll
Hello,i'm making arduino project in witch i can control diode through lcd keypad shield, test buttons and see how long arduino is working.
The issue is with diode.
Task is to increase diode brightness through shield up/down buttons.
LCD shows that brightness is increasing, but diode isn't diode "going up".
I guess issue could be code, because diode is working
DIODE PART
[code]
void MenuC() {
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Speed 0 to 250:");
  while (readKeypad() != 'S') {
    x = analogRead(masterKey);
    xmax = x;
    if (xmax > 130 && xmax < 135) {
      ledUP <= ledMAX;
      ledUP += ledstep;
      lcd.setCursor(5, 2);
      lcd.print("                ");
      analogWrite(led, ledUP);
      lcd.print(ledUP);
      delay(100);
[/code]
ALL PROJECT CODE
[code]
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int masterKey = A0;
int keypadKey = 0;
int buttonPress = 0;
char push;
byte menu = 1;
byte menuOld = 1;
byte menuAll = 4;
//______BUTTON_TEST
int x = 0;
int xmax = 1023;
String button = "None";
//_______LED_________________
byte ledUP = 0;
byte ledMAX = 255;
byte led = 2;
int ledstep = 2;
//____________
  pinMode(2, OUTPUT);
  lcd.begin(16, 2);
  mainMenu();
  delay(100);
  push = readKeypad();
  menuContr();
  if (push == 'S') //enter selected menu
    waitKey();
    switch (menu) {
      case 1:
        ButtonTest();
      case 2:
        MenuB();
      case 3:
        MenuC();
      case 4:
        SystemTime();
    mainMenu();
    waitKey();
  delay(10);
//____________________________
void ButtonTest() {
  lcd.clear();
    if ((x != 1023) && (x != xmax)) {
      lcd.setCursor(10, 0);
      lcd.print("     ");
      lcd.print(x);
      xmax = x;
      if (xmax > 475 && xmax < 480) {
        button = "Left";
      } else if (xmax < 10) {
        button = "Right";
      } else if (xmax > 130 && xmax < 135) {
        button = "Up";
      } else if (xmax > 305 && xmax < 310) {
        button = "Down";
      lcd.setCursor(0, 1);
      lcd.print("        ");
      lcd.print(button);
    delay(10);
void MenuB() {
  lcd.clear();
    lcd.print("2");
void MenuC() {
  lcd.clear();
    xmax = x;
      ledUP <= ledMAX;
      ledUP += ledstep;
      lcd.print("                ");
      lcd.print(ledUP);
      delay(100);
void SystemTime() {
  lcd.clear();
    lcd.setCursor(6, 0);
    lcd.print("TIME");
    lcd.setCursor(7, 1);
    lcd.print(millis());
    lcd.print("s");
    delay(100);
    lcd.clear();
//______________________________
void mainMenu() {
  lcd.clear();
  switch (menu) {
    case 1:
      lcd.print("Button test");
    case 2:
      lcd.print("Motor contr");
    case 3:
      lcd.print("LED contr");
    case 4:
      lcd.print("Syst run time");
void executeAction() {
  switch (menu) {
    case 1:
      ButtonTest();
    case 2:
      MenuB();
    case 3:
      MenuC();
    case 4:
      SystemTime();
void menuContr() {
  waitKey();
  if (push == 'U') {
    menu++;
    if (menu > menuAll)
      menu = 1;
  else if (push == 'D') {
    menu--;
    if (menu == 0)
      menu = menuAll;
  if (menu != menuOld) {
    mainMenu();
    menuOld = menu;
char readKeypad() {
  keypadKey = analogRead(masterKey);
  if (keypadKey < 100)
    return 'R';
  else if (keypadKey < 200)
    return 'U';
  else if (keypadKey < 400)
    return 'D';
  else if (keypadKey < 600)
    return 'L';
  else if (keypadKey < 800)
    return 'S';
    return 'N';
void waitKey() {
  while ( analogRead(masterKey) < 800) {}
[/code]
You’re doing analogWrite to pin 2.
Which board are you using?
@TheMemberFormerlyKnownAsAWOL i guess it could be keypad shield, keypad shield is connected on top of arduino
I don’t understand your reply.
@TheMemberFormerlyKnownAsAWOL I’m using lcd keypad shield, witch in mounted on arduino uno
Ok.
What does the reference say about doing analogWrite to pin 2 on a Uno?
ok i changed to pin 3, but it still didn't work
I can’t see your code.
Remove the LCD/keyboard shield and look at the designations near the pins.....
I made a quick change of a working design and made the same mistake recently....
TheMemberFormerlyKnownAsAWOL:
I can't see your code.
Why not? I can.
Railroader:
Ok, I took off shield, as i understand i'm using wrong pin.
As i understand, for analog output i must use pin 3.
And i switched to pin 3, but led diode still doesn't increase its brightness
i switched to A1 pin and it work, thanks you all
jankeljs:
Did You recompile and download the code as well?
Using A-pins for PWM is new to me. Didn't know they could do that. Checking reference now.....
Check this page: analogWrite() - Arduino Reference
Railroader:
Why not? I can.
I can’t see the amended code - how come you can?
The second code tagged window in the very first post shows it. Not the code used?
