LED Display code help
Hello everyone, I bought a Sure Electronic 3208 RED LED Matrix Display. I am trying to get it work for my school project.
I downloaded the library from this link
I installed the library inside the Arduino Libraries folder
When I run the example code
#include <HT1632.h> // Include this before <images.h> or any font.
#include <images.h>
void setup () {
    HT1632.begin(pinCS1, pinWR, pinDATA);
    // Where pinCS1, pinWR and pinDATA are the numbers of the output pins
    // that are connected to the appropriate pins on the HT1632.
void loop () {
  // The definitions for IMG_HEART and its width and height are available in images.h.
  // This step only performs the drawing in internal memory.
  HT1632.drawImage(IMG_HEART, IMG_HEART_WIDTH,  IMG_HEART_HEIGHT, (OUT_SIZE - IMG_HEART_WIDTH)/2, 0);
  HT1632.render(); // This updates the display on the screen.
  HT1632.clear(); // This zeroes out the internal memory.
  HT1632.render(); // This updates the screen display.
I got the following errors
sketch_nov10a.ino: In function ‘void setup()’:
sketch_nov10a:5: error: expected unqualified-id before ‘.’ token
sketch_nov10a.ino: In function ‘void loop()’:
sketch_nov10a:11: error: expected unqualified-id before ‘.’ token
sketch_nov10a:14: error: expected unqualified-id before ‘.’ token
sketch_nov10a:19: error: expected unqualified-id before ‘.’ token
sketch_nov10a:21: error: expected unqualified-id before ‘.’ token
it is highlighting this line
Can someone help me out? =/
BTW I am using Arduino 1.0.6. My computer is 64bit Win7.
are there more folders in the main library folder you downloaded? I had an issue that might be similar to this with the fft library and needed to remove a folder from within for it to be able to recognize the .h file.
