Hi. I am using an UNO R3 and a MAX7219 8 Digit Seven Segment Display Module (HCMODU0082) from HobbyComponents. The libraries are available on their page and some example sketches. Here:
Hmmm, Insert Hyperlink doesn't work?
HCMAX7219 - LED driver library - forum.hobbycomponents.com
What I'm trying to achieve for starters, is just to write HELLO !! on the display as suggested in their code. It doesn't work...
/* Include the HCMAX7219 and SPI library */
#include <HCMAX7219.h>
#include "SPI.h"
/* Set the LOAD (CS) digital pin number*/
#define LOAD 10
/* Create an instance of the library */
HCMAX7219 HCMAX7219(LOAD);
HCMAX7219.Init();
/* Main program */
/* Clear the output buffer */
HCMAX7219.Clear();
/* Write some text to the output buffer */
HCMAX7219.print7Seg("HELLO !!",8);
/* Send the output buffer to the display */
HCMAX7219.Refresh();
while(1);
They also have a scrolling text sketch example that does work but Im less interested in that. Can anybody see why it's broken please?
Oh yes it does
http://forum.hobbycomponents.com/viewtopic.php?f=58&t=1794
It doesn't work...
You gave no indication of what happens when you run the program
Did you mean to print starting at position 8 ?
OK, so Insert Hyperlink likes you better.
The code compiles and then does nothing. Absolutely nothing. I run a similar code with a couple more bits n bobs in it and it runs...
#include "SPI.h"
#define LOAD 10
HCMAX7219.Init();
/* Main program */
byte Loopcounter;
byte Position;
/* SCROLL SOME TEXT 5 TIMES BEFORE MOVING ON */
for (Loopcounter = 0; Loopcounter <= 5; Loopcounter++)
/* We are scrolling 30 characters of text across the entire display */
for (Position = 0; Position <= DISPLAYBUFFERSIZE + 30; Position++)
/* Write the test to the output buffer at the position we require */
HCMAX7219.print7Seg("HCMAX7219 SCROLLING TEXT DEMO ",Position);
delay(200);
/* WE CAN ALSO DISPLAY INTEGER NUMBERS */
HCMAX7219.Clear();
/* Write some text and output it*/
HCMAX7219.print7Seg("INT NUM.",8);
delay(2000);
/* display an example of a negative integer number */
HCMAX7219.Clear();
HCMAX7219.print7Seg(-1234567,8);
delay(2000);
HCMAX7219.Clear();
HCMAX7219.print7Seg("WITH DP.",8);
delay(2000);
/* Show the DP in different places. Notice when the DP is at the
beginning the number is padded with a zero */
HCMAX7219.Clear();
for (Position = 1; Position <= 7; Position++)
HCMAX7219.print7Seg(-1234567,Position,8);
Basically produces some gibberish at the end, but runs anyway.
I did not mean to print starting at position 8 (I didn't write the code, got it as an example...) and as they do not comment on it, it seemed that it was an indicator of the amount of segments to write over?
I Actually just want a bit of code that writes something to the display the moment I turn it on but I'm not familiar with displays yet, let alone LED's. Can you help?
Just to be clear. The scrolling text example on the sire works but the static text example doesn't. Is that correct ?
Just for amusement can you try setting the second parameter in print7Seg() to 1 in the static text example
Nope, 1, zero, 2 etc. No result. I understand why they Clear() the display but not sure why they refresh it after it renders? Also, the line; while(1), I don't get?
Yes, the code for scrolling text works (2nd example). I stripped it down to just one line of display and it runs it perfectly in a loop...
As soon as I remove the code to loop, it stops.
This leaves me with:
and that looks the same as their first example except for "Position" for the increment in segment position. Replacing that with zero or 1 should work? I am missing something simple.
That's the way it looks to me.
Replace Position in the call to Refresh in the scrolling code with a 1 as you alluded to. The for loop is not necessary but can stay there for now.
That causes the program to repeat that line forever, ie stop updating the display
HCMAX7219.Clear();
The comments above the function calls tell you what they are doing.
