Hi, does anyone know why my led is not turning on completely.
One month ago, with the same circuit, the LED turned on just fine, but now that i am trying to do it again, i barely see the light.
Or is a malfunction of the ARduino ??
No.
Probably not - who knows?
(deleted)
Yes, sorry.
int led=7;
pinMode(led,OUTPUT);
digitalWrite(led,HIGH);
digitalWrite(led,LOW);
int LDR=analogRead(A0);
Serial.println(LDR);
if(LDR<100)
if(LDR>100)
Depends on what that "LED does not completely turn on" means.
Does it emit a dim light?
Does it blink right when the sketch is starting?
If it does not, you probably have something wrong with a LED. It is burnt out? The current limiting resistor is cracked or any other extra resistance in the chain? Some cold soldering?
If the LED flashes right on a start and gets dim after, maybe your LDR is fluctuating near 100 and LED goes on and off producing kinda PWM signal?
What is the serial monitor telling you?
Have you tried the led and its resistor across the Arduino 5V output (ie, not an i/o pin) and ground?
I have changed the resistor and the LED and everything remains the same.
No, since the beggining, the LED blink but really low and stays that way.
I tried the same with a different arduino and all went well, i think the arduino is not giving the enough current or something like that??
What is the value of your resistor? is the LED a 'normal' one or is it a 5v or 12v specific.
What is the output of the LED\resistor when connected across 5V and ground? how bright is it?
