led does not go on or of
digitalRead(8) == buttonPushCounter ;
What do you imagine that does?
Please talk us through it.
((digitalRead(8) == 3)That is never, ever going to happen.
We've been through this before.
when the button is pushed it ad on counter +1
Please review this:
opelvectra:
Open the IDE.
Click on. "files", scroll down to "examples".
Start with "01" .
i already did the examples for my test it dont help allot
Maybe try them again.
You missed a lot (note spelling) of the key points.
You need to ‘master’ those examples before you proceed.
ill try i dotn have that much time i have to fill my example code soon
You'd be better ignoring your code, and concentrating on the basics.
opelvectra:
From the Button example
  buttonState = digitalRead(buttonPin);
From your code
Do you see a difference ?
Pin 8 is high or low state from it
digitalRead(8) ==buttonPushCounter ;
Nothing beacause pin 8 can be just high or low ?
No. buttonState will be HIGH or LOW depending on the state read from buttonPin
No. digitalRead() returns a HIGH or LOW value. You cannot change the state of an input pin using digital[u]Read/u The clue is in the name
Is pointless - you're comparing two entities (the return value of digitalRead (8) and the variable buttonPushCounter).
The comparison will be true if they're equal, false if they're not.
But you're not doing anything with that true or false, so all you've done is waste a few microseconds.
Got it read only reads if the. Pon is high or low stil can figuere outhow to put this in a while functie whit if and else its easyer
if (digitalRead(somePin) == LOW)  //execute the code once if true
    //execute this code
while (digitalRead(somePin) == LOW)  //execute code repeatedly until the test is false
    //execute this code
//execute this code
Can while be maked twice for on and off function and do i add a counter in de execute code ?
please review and understand how the following code recognizes a button press and increments a count displayed on the serial interface
const byte ButPin       = 8;
int   buttonPushCounter = 0;
byte  butLast           = HIGH;
    Serial.begin (9600);
    pinMode(ButPin, INPUT_PULLUP);      // configure with pullup
    byte  but = digitalRead(ButPin);    // read pin
    if (butLast != but)  {              // check for a change
        butLast = but;                  // capture new state
        if (LOW == but)  {              // check if FALLING
            buttonPushCounter++;
            Serial.println (buttonPushCounter);
I asked the teacher how it has to be my program has to be in a while loop when he hits the 3 eacht time so i created a new on but still o mis something
  pinMode(8, INPUT_PULLUP);
  pinMode(4, OUTPUT);
delay(100);
int buttonpush = 0:
  while (buttonpush < 3){
    if (8 ==true )
     buttonpush = buttonpush +1
  if (8 == false);
    4 = true ;
  if (8 == true)
    4= false;
 if (8 ==true )
Again?
Seriously, work through some examples.
Let it sink in.
if (8 == false); If you had worked through any of the examples, you would NEVER have seen a semicolon like that.
Not once
And of course, 8 will never be false
pin 8 may, of course, be HIGH or LOW if that helps
