Hello!
I want to build Arduino Piano, that on the same time teaches you how to play on it.
It has got LEDs, that should light up when I use a learn mode. Each LED is for each button. When it lights up, that should mean, that we have to press that button.
No LEDs light up.
This is my code:
#include <Tone.h>
// Kuža pazi - notes converted
// Copyright
int notes_kuzapazi[] = {NOTE_C4, NOTE_C4, NOTE_C4, NOTE_C4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_E4, NOTE_E4, NOTE_D4, NOTE_D4, NOTE_C4, NOTE_C4, NOTE_C4, NOTE_C4};
// Here are defined some important variables
int note = 0;
char text;
boolean songlearn = false;
// Here are defined LEDs for learning
const int led_c1 = 11;
const int led_d1 = 12;
const int led_e1 = A0;
const int led_f1 = A1;
const int led_g1 = A2;
const int led_a1 = A3;
const int led_h1 = A4; // USA uses B instead H
const int led_c2 = A5;
// Here are defined all the buttons for playing
const int c1 = 2;
const int d1 = 3;
const int e1 = 4;
const int f1 = 5;
const int g1 = 6;
const int a1 = 7;
const int h1 = 8; // USA uses B instead H
const int c2 = 9;
const int speaker = 10;
Tone tone1; // Here are tones defined
// Function to turn all leds off
void turnoffall(){
digitalWrite(led_c1, LOW);
digitalWrite(led_d1, LOW);
digitalWrite(led_e1, LOW);
digitalWrite(led_f1, LOW);
digitalWrite(led_g1, LOW);
digitalWrite(led_a1, LOW);
digitalWrite(led_h1, LOW);
digitalWrite(led_c2, LOW);
void kuzapazi_refren(){
for (note = 0; 15 > note; note++){
tone1.play(notes_kuzapazi[note]);
delay(250);
tone1.stop();
delay(100);
void kuzapazi_learn(){
songlearn = true;
text = notes_kuzapazi[note];
Serial.println(note);
while (songlearn==true){
if (text=="NOTE_C4"){
Serial.println(text);
digitalWrite(led_c1, HIGH);
if (digitalRead(c1)==HIGH){
turnoffall();
songlearn=false;
else if (text=="NOTE_D4"){
Serial.println("d1");
digitalWrite(led_d1, HIGH);
if (digitalRead(d1)==HIGH){
turnoffall();
songlearn=false;
else if (text==NOTE_E4){
Serial.println("e1");
digitalWrite(led_e1, HIGH);
if (digitalRead(e1)==HIGH){
turnoffall();
songlearn=false;
// Define speaker
pinMode(speaker, OUTPUT);
tone1.begin(speaker);
// Serial begin
// Define Buttons
pinMode(c1, INPUT);
pinMode(d1, INPUT);
pinMode(e1, INPUT);
pinMode(f1, INPUT);
pinMode(g1, INPUT);
pinMode(a1, INPUT);
pinMode(h1, INPUT);
pinMode(c2, INPUT);
// Define LEDs
pinMode(led_c1, OUTPUT);
pinMode(led_d1, OUTPUT);
pinMode(led_e1, OUTPUT);
pinMode(led_f1, OUTPUT);
pinMode(led_g1, OUTPUT);
pinMode(led_a1, OUTPUT);
pinMode(led_h1, OUTPUT);
pinMode(led_c2, OUTPUT);
turnoffall();
kuzapazi_learn();
tone1.play(NOTE_C4);
Serial.println("c1");
delay(30);
tone1.stop();
else if (digitalRead(d1)==HIGH){
tone1.play(NOTE_D4);
delay(30);
tone1.stop();
else if (digitalRead(e1)==HIGH){
tone1.play(NOTE_E4);
delay(30);
tone1.stop();
else if (digitalRead(f1)==HIGH){
Serial.println("f1");
tone1.play(NOTE_F4);
delay(30);
tone1.stop();
else if (digitalRead(g1)==HIGH){
Serial.println("g1");
tone1.play(NOTE_G4);
delay(30);
tone1.stop();
else if (digitalRead(a1)==HIGH){
Serial.println("a1");
tone1.play(NOTE_A4);
delay(30);
tone1.stop();
else if (digitalRead(h1)==HIGH){
Serial.println("h1");
tone1.play(NOTE_B4);
delay(30);
tone1.stop();
else if (digitalRead(c2)==HIGH){
Serial.println("c2");
tone1.play(NOTE_C5);
delay(30);
tone1.stop();
I'm using a Tone library.
Does anybody know what is wrong?
Thank you so much
Mitjas
