Hello everybody,
I'm trying to make the project 19 of the book Beginning Arduino by Michael McRoberts, but I have a hard time not find solution anywhere.
Here are the problems:
The project code 19 of the book is this:
#include <TimerOne.h>
int latchPin = 8; //Pin connected to Pin 12 of 74HC595 (Latch)
int clockPin = 12; //Pin connected to Pin 11 of 74HC595 (Clock)
int dataPin = 11; //Pin connected to Pin 14 of 74HC595 (Data)byte led[8]; // 8 element unsigned integer array to store the sprite
pinMode(latchPin, OUTPUT); // set the 3 digital pins to outputs
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
led[0] = B11111111; // enter the binary representation of the image
led[1] = B10000001; // into the array
led[2] = B10111101;
led[3] = B10100101;
led[4] = B10100101;
led[5] = B10111101;
led[6] = B10000001;
led[7] = B11111111;
// set a timer of length 10000 microseconds (1/100th of a second)
Timer1.initialize(10000);
// attach the screenUpdate function to the interrupt timer
Timer1.attachInterrupt(screenUpdate);
}void loop() {
for (int i=0; i<8; i++) {
led_= ~led*; // invert each row of the binary image*_
* delay(500);*
void screenUpdate() { // function to display image
* byte row = B10000000; // row 1*
* for (byte k = 0; k < 9; k++) {*
* digitalWrite(latchPin, LOW); // open latch ready to receive data*
* shiftIt(~led[k] ); // shift out the LED array (inverted)*
* shiftIt(row ); // shift out row binary number*
* // Close the latch, sending the data in the registers out to the matrix*
* digitalWrite(latchPin, HIGH); *
* row = row >> 1; // bitshift left*
* delay(1);*
void shiftIt(byte dataOut) { // Shift out 8 bits LSB first, on rising edge of clock
* boolean pinState;*
* digitalWrite(dataPin, LOW); //clear shift register read for sending data*
* for (int i=0; i<8; i++) { // for each bit in dataOut send out a bit*
* digitalWrite(clockPin, LOW); //set clockPin to LOW prior to sending bit*
* // if the value of DataOut and (logical AND) a bitmask*
* // are true, set pinState to 1 (HIGH)*
* if ( dataOut & (1<<i) ) {*
* pinState = HIGH;*
* else {*
* pinState = LOW;*
* //sets dataPin to HIGH or LOW depending on pinState*
* digitalWrite(dataPin, pinState);*
* digitalWrite(clockPin, HIGH); //send bit out on rising edge of clock*
* digitalWrite(dataPin, LOW);*
digitalWrite(clockPin, LOW); //stop shifting
[/quote]
I typed the code and did not work at first. I thought the problem was the circuit that use shift register, did the countless tests and realize that I was correct. One of the test was to count binary column and row and it worked correctly.
When I added 'delay (1)' on line 44, the project works almost perfectly (some blinking leds that was not to be fishing).
I'm new to the Arduino world ... and not know where to go right now. In another project related to LED Dot Matrix had already partially solved this problem adding a 'delay (1)'.
anyone have any suggestions for my question?
Sorry for my English (by google translate :D)
thank you
_*See the same project but with Matrix Common Cathode: http://mindovermaterial.wordpress.com/2012/07/17/beginning-arduino-project-19-led-dot-matrix-basic-animation/*_
