LED Driver + Mosfet / Linear Led?
Hello,
I need some help on what to do, or if there are any other options or parts that I can easily implement.
I have a 100W Led chip,
My power supply is rated 12V 120W, and I have added a booster to get 30V, less than 100W.
Currently, I have arduino mega, connected Pwm pins to mosfet, which controls the led chip. My input comes from a potentiometer, which is mapped as pwm=map(0,1023,0,255).
The problem was, the dimming on the led was steppy, it would go in steps. I tried different mapping, increase and decreasing number for bottom half and top half, etc. but no luck.
I also tried, doing 16bit pwm, had very less effect. but better i guess.
My question is:
  1. Could anyone tell me how to calibrate a led curve? or should I try everynumber 0-255, then try different arrays and work with that?
  2. I read that leds are dimmed using constant current dim method.
    So, would connecting a led driver to the mosfet, have better control?
Led driver
  1. I have tried, using a low pass filter circuit. that didn't work either. Should a DAC which converts pwm to analog voltage be better option?
If you need more information, please let me know.
How are you powering your LED?
Can yu post a picture of your project so we can see your component layout.
LED like that really needs a current controlled driver, 100W.
If you are using 12V supply you need it to be able to supply…
P = V * I
SO I = P / V
I= 100 / 12 = 8.33A
The sparkfun device does not have the current carrying capacity.
Have you googled?.. arduino LED driver
This may help… Loading...
Tom… :slight_smile:
You can't properly drive an LED with a constant voltage and a MOSFET. LEDs are driven from a constant current source. You can buy a [u]constant current LED supply[/u] or you can build one, but they are not easy to build. (A regular little LED is current-controlled by a resistor. But, you probably don't want to use a ~100W resistor in series with your 100W LED.)
The industry standard for dimming control is 0-10VDC or 10V PWM, so if you by a dimmable power supply you'll still need a small transistor or MOSFET (and an ~10V power supply) to "boost" the Arduino's output voltage.
The "curve" probably isn't the issue. When step from 1 to 2, that's a 100% increase, and you might notice the change. A step from 254 to 255 is less than 1/2% and you probably won't see it.
Analog into your MOSFET won't work because if the MOSFET is "half-on" it will overheat. 16-bit analog or 16-bit PWM into a constant-current supply would give you more resolution. (With 16-bits you have 256 times as many steps... More than 60,000 steps.)
P.S.
The LED also needs a heatsink!
This 100watt COB LED (10101watt LED) needs ~33-35volt, with a constant current of 3Amp.
Not sure what you were thinking there (300mA).
"My power supply is rated 12V 120W, and I have added a booster to get 30V, less than 100W".
Needs to be 36volt minimum for the LED and the losses in the driver, and capable of 3Amp.
"Currently, I have arduino mega, connected Pwm pins to mosfet, which controls the led chip."
A "LED chip" (like the ones from Sparkfun) already have the switching circuitry onboard.
Adding a mosfet is wrong.
"The LED also needs a heatsink!"
Yep, a beefy CPU cooler with fan is needed for a 100watt LED.
Leo..
