system
September 14, 2014, 7:03pm
1
I'm a beginner in Arduino and I came across this while I was familiarizing with the codes and functions. As the title says, when I use randomSeed, LEDs emits low light. Per LED, I series 1kOhm limitting resistor. I tried to change it with a lower value (In some forums they said 100 Ohms is the recommended minimum value, tried it but still gets the same result). I tried also to change the LEDs to know if they are faulty, but it seems that they are not the problem. Then I tried another sketch I found on the internet utilizing the random() function. this is the code:
int ledRed = 2;
int ledGreen = 3;
int ledYellow = 4;
int ledBlack = 5;
pinMode(ledRed, OUTPUT);
pinMode(ledGreen, OUTPUT);
pinMode(ledYellow, OUTPUT);
pinMode(ledBlack, OUTPUT);
Serial.println(random(5));
digitalWrite(ledRed, random(5));
digitalWrite(ledGreen, random(5));
digitalWrite(ledYellow, random(5));
digitalWrite(ledBlack, random(5));
The LEDs then light up normaly, emitting its normal light intensity. What could be the problem? Thanks in advance for the help.
random(5)
Returns a number from zero to four.
How about
random(256)
Which will return a number between zero and 255 inclusive.
Plus, you want
analogWrite(pin, random(256));
Where did you randomSeed?
What's a black led do?
MarkT
September 15, 2014, 12:08am
3
I see no call to randomSeed. You are clearly not talking about the code you posted.
system
September 15, 2014, 7:30am
4
Here's the code. The ledBlack is just a variable. Random name only sorry.
long randNumber;
pinMode(randNumber,OUTPUT);
randomSeed(analogRead(0));
int randNumber = random(7,12);
digitalWrite(randNumber,HIGH);
digitalWrite(randNumber,LOW);
system
September 15, 2014, 8:17am
5
Pins are INPUT by default. An LED on an INPUT pin will not be very bright.
system
September 15, 2014, 8:58am
6
So I should first set my 8-11 pins as OUTPUT on setup() for them to light up bright?
system
September 15, 2014, 9:14am
7
PaulS:
That did it. Thanks for the help good sir.
you may want to try your original sketch, but like this:
int ledRed = 2;
int ledGreen = 3;
int ledYellow = 4;
int ledBlack = 5;
Serial.println(random(0,2));
digitalWrite(ledRed, random(0,2));
digitalWrite(ledGreen, random(0,2));
digitalWrite(ledYellow, random(0,2));
digitalWrite(ledBlack, random(0,2));
