LED fade and delay function
Hi Guys,
I'm up to the next stage of my project now and need a bit of help with the LED fade code.
I've got seven different sets of values which I assign with a switch case... this all works fine.
The idea is to map the led value and then use a time counter to increment the fadeR,G,B.
This all worked pretty well.
Now I need to stagger each succeeding LED so they come on one after the other and this has broken the code due to exceeding the time of 100.
I'm wondering if I should try rewriting the whole thing and use an array of values for each pixels RGB values... maybe this would help?
Any suggestions would be great.
Thanks!
Chris
// Main function used to chase the LEDs up and down
void chase(byte valR, byte valG, byte valB)
  //maths to work out increment for each colour
  uint8_t fadeR = constrain(map(time, 0, 100, 0, valR+10),0,100);
  uint8_t fadeG = constrain(map(time, 0, 100, 0, valG+10),0,100);
  uint8_t fadeB = constrain(map(time, 0, 100, 0, valB+10),0,100);
  //chase the colour on
  currenttime = millis();
  // main bit of code
    if(currenttime - previoustime > interval) // tells the function the interval at which to increment the LED brightness
      for(int i=0; i<pixel.numPixels(); i++) // incremments the LED so that you can light up multiple
            fadeDR = fadeR-(i*DELAYINT);
            fadeDG = fadeG-(i*DELAYINT);
            fadeDB = fadeB-(i*DELAYINT);
            pixel.setPixelColor(i,curve(fadeDR),curve(fadeDG),curve(fadeDB)); // tells the LED what value it should be at
            time++;
            pixel.show();
            //lastButton = 8;
      } // close for loop
      previoustime = currenttime;
    } //   close if loop
}    //    close function
Please post ALL your code.
My crystal ball has crashed, so I can't tell what value DELAYINT has.
RaraAvis:
You need to rethink what it is you're trying to do.
You only need to change 2 leds at a time yet you process the whole array every time.
Also, I have no idea of what the apparent code object pixel does and no inclination to find out.
Does it by any chance have built-in delays?
