Hi, I'm trying to combine two bits of basic code from the starter kit. The fade and button sketch, where, while my finger is pressed down the LED comes on and fades on and off. Simple but I can't combine the two 'if' statements and can't find a video on it. Use code tags to format code for the forum
<CODE/>
int led = 3; // the PWM pin the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int buttonState=0;
int buttonPin=8;
// the setup routine runs once when you press reset:
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
pinMode(buttonPin, INPUT);
// the loop routine runs over and over again forever:
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH);{
digitalWrite(led,HIGH);}
else{ digitalWrite (led,LOW);}}
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255) {
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
int buttonState = 0;
int buttonPin = 8;
// digitalWrite(led, HIGH);
// set the brightness of pin 3:
delay(30);
digitalWrite (led, LOW);
int buttonState = 1;
int buttonPin = 8;
//is button down..
bool down = false;
//millis timer for btn debounce
unsigned long lastRead = 0;
//millis timer for fade
unsigned long lastDim = 0;
//interval delay for each fade step
int intervalDim = 30;
//are we giong up or down//
bool dimming = true;
// pinMode(led, OUTPUT); //not needed for analog
//switched to use internal pull up..
//this reveres button logic..
pinMode(buttonPin, INPUT_PULLUP);
//what time is it now..
unsigned long now = millis();
if (now - lastRead >= 50) {
byte btn = digitalRead(buttonPin);
if (btn != buttonState) {
lastRead = now; //start debouncing..
buttonState = btn;
if (btn == LOW) {
if (!down) {
brightness = 255;
dimming = true;
down = true;
down = false;
analogWrite(led, 0);
if (down) {
if (now - lastDim >= intervalDim) {
lastDim = now;
if (dimming) {
brightness -= fadeAmount;//subtract fade
if (brightness == 0) dimming = false;
brightness += fadeAmount;//add fade
if (brightness == 255) dimming = true;
breaking change is switching to use input pull ups but will be better or you have external pull down resistors, i'm thinking no, hence the pull ups..
add debounced to the button..
removed use of delay and replaced with millis timer for fade effect..
delay() function makes your sketch sit and wait, not good when you want to watch for buttons..
Thanks for helping. This worked perfectly only the LED was on permanently and faded only when the button was being pressed. I haven't encountered some of that C++ you used yet but really good for reference thank you
