LED fade will not listen to IR input for interupt.
You've ignored my comment about getIR not doing anything useful. It's nice to format the code, but don't overlook the comments about the code itself.
It looks to me like you are calling getIR inside the loop which fades LEDs, so having it work properly would be helpful.
I'm not ignoring the comments, I was just mentioning that I was going back and forth between using IF statements and While statements. Doesn't seem to be much difference, except the IF statements work better. I can try to move the detection portion of the code to a function, then just call that function. The only thing I am having trouble with is, when I press a button on the remote, it seems like it continues with the fade math. Almost like by the time the entire code from the remote has been transmitted, the Arduino is already past the function to look for code, and is back handling math for the fade. I am wondering if it is possible at all to have it fade some LEDs and at the same time, keep an eye on the IR_RCV pin waiting for a button press.
UKHeliBob:
If you don't insert the code to look for an IR signal the loop is not going to exit, is it ?
As a matter of interest, why all the maths ? Will statements like these always give a result between 0 an 255 ?
        value = 128+127*cos(2*PI/periode*time);
value2 = 128+127cos(2PI/periode*(displace-time));
        value3 = 128+127cos(2PI/periode*(testtime-time));
To be honest, i am not 100% sure. I know it is a small fader for the LEDs. I have 2 faders, one I can customize nicely, and this one.
In the future, I hope to make a few scripts to blink LEDs to react to sound, but different settings.
It seems to me that one of the problems for you and those trying to help is that the current sketch is complicated to understand in its own right without trying to shoehorn reading the IR into it. There is a lot going on in the sketch and I for one cannot see the wood for the trees. For instance, the crossFade function is called with a parameter of color[3] but the color array is not defined in the sketch nor is there any attempt to use the value of color[3] in the function. Needless to say the sketch will not compile.
I would suggest that you start with a much simpler sketch, get it working then add to it. How about a sketch to respond to button presses to turn on or off a single LED ? In my experience there is a world of difference between trying to understand and modify a program written by someone else and writing one yourself.
UKHeliBob:
This script is more of a Frankenstein. Parts of it were inspired from other code. I am going to explore using a pin change interrupter to do the dirty work of the yellow button which is, for the time being, my all stop button. Because I have no formal or book training, I write code based on my thought pattern which is much like RAM on any computer, all over the place.
I will explore other options and start a new thread with simpler easier to understand code if I get stuck. Thanks!
for (int i = 0; i <= 1020; i++) {
    redVal = calculateVal(stepR, redVal, i);
    grnVal = calculateVal(stepG, grnVal, i);
    bluVal = calculateVal(stepB, bluVal, i);
    analogWrite(redPin, redVal);   // Write current values to LED pins
    analogWrite(grnPin, grnVal);
    analogWrite(bluPin, bluVal);
    int zag = 1;
    do {
      zag = zag + 1;
      getIR();
    while (zag < 200);
There is nothing in that loop (from 0 to 1020) that leaves the loop early (if you press a button on the remote or for any other reason). You need to address that first.
    int zag = 1;
    do {
      zag = zag + 1;
      getIR();
    while (zag < 200);
What does that do? It gets the IR remote value 199 times. Why? Why not once?
void getIR() {
  IRrecv irrecv(RECV_PIN);
  decode_results nresults;
You are making a second instance of irrecv (the first being global) which is then immediately destroyed. The value nresults is not used anywhere.
Since I don't know or dont fully understand how to get it to check for that push in t he middle of a fade. I decided to try an interupt, which did not help. Here is the new code, and I cleaned it up using AutoIT Cleaner:
Any thoughts would be greatly appreciated
#include <IRremote.h>
int pbIn                    = 0;
volatile int state          = LOW;
int RECV_PIN                = 11;
int periode                 = 2000;
int displace                = 500;
int testtime                = 1000;
long time                   =0;
/* FUTURE USE
int RED1                    = 2
int GREEN1                  = 3
int BLUE1                   = 4
int RED2                    = 5
int GREEN2                  = 6
int BLUE2                   = 7
int RED3                    = 8
int GREEN3                  = 9
int BLUE3                   = 10
int RED4                    = 11
int GREEN4                  = 12
int BLUE4                   = 13
int redPin                  = 7;
int grnPin                  = 6;
int bluPin                  = 8;
int value, value2, value3;
int RED                     = 7;
int GREEN                   = 6;
int BLUE                    = 8;
// Color arrays
int black[3]                = { 0, 0, 0 };
int white[3]                = { 100, 100, 100 };
int red[3]                  = { 100, 0, 0 };
int green[3]                = { 0, 100, 0 };
int blue[3]                 = { 0, 0, 100 };
int yellow[3]               = { 100, 100, 0 };
int pink[3]                 = { 0, 100, 100 };
int magenta[3]              = { 100, 0, 100 };
// etc.
// Set initial color
int redVal                  = black[0];
int grnVal                  = black[1];
int bluVal                  = black[2];
int prevR                   = redVal;
int prevG                   = grnVal;
int prevB                   = bluVal;
long previousMillis         = 0;
long interval               = 1000;
long chill                  = 2;
int ledState                = LOW;
int blinkone                = 0;
int blinktwo                = 0;
int blinkthree              = 0;
int blinkfour               = 0;
int blinkfive               = 0;
int blinksix                = 0;
int blinkseven              = 0;
int blinkeight              = 0;
int blinknine               = 0;
int val;
decode_results results;
void setup(){
attachInterrupt(pbIn, CheckYellow, HIGH);
pinMode(8, OUTPUT);
pinMode(7, OUTPUT);
pinMode(6, OUTPUT);
irrecv.enableIRIn();
if (irrecv.decode(&results)) {
if (results.value           == 0x66B47) { // BLUE button on the remote
digitalWrite(BLUE, HIGH);
else if (results.value      == 0xE6B47) { // RED button on the remote
digitalWrite(RED, HIGH);
else if (results.value      == 0x490) { // Vol Up button on the remote
interval                    = interval - 50;
if (interval < 75) {
interval                    =100;
else if (results.value      == 0xC90) { // Vol Down button on the remote
interval                    = interval + 50;
else if (results.value      == 0x290) { // Vol Down button on the remote
interval                    = 1000;
else if (results.value      == 0x16B47) { // GREEN button on the remote
digitalWrite(GREEN, HIGH);
// else if (results.value   == 0xB47) { // 1 button on the remote
while (results.value        == 0xB47) {
time                        = millis();
value2                      = 128+127*cos(2*PI/periode*(displace-time));
value3                      = 128+127*cos(2*PI/periode*(testtime-time));
analogWrite(redPin, value);
analogWrite(grnPin, value2);
analogWrite(bluPin, value3);
else if (results.value      == 0x80B47) { // 2 button on the remote
blinkone                    = 1;
else if (results.value      == 0x40B47) { // 3 button on the remote
else if (results.value      == 0xC0B47) { // 4 button on the remote
else if (results.value      == 0x20B47) { // 5 button on the remote
else if (results.value      == 0xA0B47) { // 6 button on the remote
else if (results.value      == 0x60B47) { // 7 button on the remote
while (results.value        == 0x60B47) {
crossFade(red);
crossFade(green);
crossFade(blue);
crossFade(yellow);
crossFade(white);
crossFade(pink);
crossFade(magenta);
else if (results.value      == 0xE0B47) { // 8 button on the remote
else if (results.value      == 0x10B47) { // 9 button on the remote
else if (results.value      == 0x96B47 ) { // YELLOW - shut everything off. aka blackout
digitalWrite(BLUE, LOW);
digitalWrite(RED, LOW);
digitalWrite(GREEN, LOW);
blinkone                    = 0;
if (blinkone                == 1) { // First flash pattern. On and off
if(currentMillis - previousMillis > interval) {
previousMillis              = currentMillis;
if (ledState                == LOW);
ledState                    = HIGH;
else{
ledState                    = LOW;
digitalWrite(BLUE, ledState);
} //include this
int calculateStep(int prevValue, int endValue) {
int step                    = endValue - prevValue;
if (step) { // If its non-zero,
step                        = 1020/step;
return step;
int calculateVal(int step, int val, int i) {
if ((step) && i % step      == 0) { // If step is non-zero and its time to change a value,
if (step > 0) { // increment the value if step is positive...
val += 1;
else if (step < 0) { // ...or decrement it if step is negative
val -= 1;
// Defensive driving: make sure val stays in the range 0-255
if (val > 255) {
val                         = 255;
else if (val < 0) {
val                         = 0;
return val;
void CheckYellow() {
loop();
void crossFade(int color[3]) {
  // Convert to 0-255
  int R = (color[0] * 255) / 100;
  int G = (color[1] * 255) / 100;
  int B = (color[2] * 255) / 100;
  int stepR = calculateStep(prevR, R);
  int stepG = calculateStep(prevG, G);
  int stepB = calculateStep(prevB, B);
void getIR() {
I have also tried setting the function like this:
void getIR() {
if (irrecv.decode(&results)){
  loop();
and tried
void getIR() {
  loop();
and putting
getIR();
in various places in the fade function. The only 2 things that happen are either the fade doesnt work at all, or it works fine but refuses to stop for the yellow button.
you got the part in there which says
if ( ir value == some value )
while (ir value == some value)
// doing something here
and that is not going to work unless sometime is updating the value of "ir value"
You either need an interrupt code which is going to possible change this while the while() loop is running,
or else you need so code inside the while() loop which might change that ir value variable.
If it is there, I don't see it. Which could explain why that bit keeps on running indefinitely.
If I am reading your code right you have
pbIn is set to 0 so I interpret that as "call the CheckYellow function when the pin associated with interrupt 0 is HIGH"
Although I freely admit that I am not familiar with interrupts, reading the reference pages I see that interrupt 0 is associated with pin 2 and that the possible values of the third parameter of attachInterrupt() are LOW, CHANGE, RISING OR FALLING.
Have you got anything attached to pin 2 ?
What will happen with the parameter set to HIGH ?
If the interrupt ever causes the CheckYellow function to be called
    loop();
This calls the loop() function. What is that all about ?
Your code won't compile for me because I don't have the library but there are also other errors reported
sketch_jan16a:69: error: 'IRrecv' does not name a type
sketch_jan16a:70: error: 'decode_results' does not name a type
sketch_jan16a.ino: In function 'void setup()':
sketch_jan16a:76: error: 'irrecv' was not declared in this scope
sketch_jan16a.ino: In function 'void loop()':
sketch_jan16a:80: error: 'irrecv' was not declared in this scope
sketch_jan16a:80: error: 'results' was not declared in this scope
sketch_jan16a.ino: In function 'void CheckYellow()':
sketch_jan16a:184: error: 'results' was not declared in this scope
sketch_jan16a.ino: In function 'void getIR()':
sketch_jan16a:211: error: 'IRrecv' was not declared in this scope
sketch_jan16a:211: error: expected `;' before 'irrecv'
sketch_jan16a:212: error: 'decode_results' was not declared in this scope
sketch_jan16a:212: error: expected `;' before 'nresults'
Your code has got so mangled through attempts to fix problems that it is practically unreadable. Can I suggest that you create an example of what you want to do, keeping it as simple as possible as I for one cannot see the wood for the trees.
It's all about heartache and hair-loss, that's what it's about.
Even well-controlled recursion is risky on a RAM-limited micro.
Have you seen the dictionary definition of recursion ?
"See recursion"
UKHeliBob:
    loop();
sketch_jan16a:211: error: expected ;' before 'irrecv' sketch_jan16a:212: error: 'decode_results' was not declared in this scope sketch_jan16a:212: error: expected ;' before 'nresults'
It actually compiles for me with no errors, and it may be because I have extra libraries. Also, I am using compiler version 1.0.1 , not sure if that helps. As far as the interrupt, I have the output pin of the IR receiver going to pin 2, which in a perfect world would register as HIGH the moment I hit a button on the remote. I am trying to keep the interrupt code small, so I wanted it to check and decode looking for only one value, the yellow button.
I tried cleaning the code using some autoit apps I came across, but it keeps stripping out needed operators. I don't have any formal programming training, so this is kind of thrown together by an amateur :wink:
As for the WHILE after the IF statement, the only reason I have that is because it will only execute the pattern once and stop otherwise. When I added WHILE, it actually loops the pattern which is what I was going for.
Even with the IRremote library it will not compile for me. Does the IRremote library depend on others ?
You say that "I have the output pin of the IR receiver going to pin 2" I cannot see where that is defined in your code, nor can I see a pinMode definition for pin 2. Have I missed it ?
Cleaning the code with an an autoit app sounds like a nightmare. Was it written specifically to tidy Arduino code ? What does it try to do ? Putting each brace on its own line would be a start I suppose.
I don't know what you mean about the WHILE after the IF. I was questioning calling loop() from the CheckYellow() function though.
UKHeliBob:
I was pulling from attachInterrupt() - Arduino Reference
If I understand it, int.0 is supposed to point to pin 2 on the Arduino Mega. Essentially, i wanted it to perform this logic:
While in the fade, if you see any change in activity on pin2 which is also connected to the emitter of the IR REC, then determine what code is being sent. If the code is the same as my yellow button, then you can jump out of what you are doing, and go back to the loop.
As for the includes, I will get a list of includes i have on my laptop at home and let you know.
My mental logic which is flawed (because if it wasn't, then this would work) indicated that having an interrupt could call this:
    loop();
to execute the intended logic above. I'm sure you can see where I am trying to go with it, I just cant fin that little nitch that would actually make it work. Once I get past this hurdle, I can grow the code to all new heights.
The reason the code looks so complicated is i have so many declarations, it looks like they make up half the script. At the moment, there are 2 fade options, one simple, one complex and configurable. It also has a blink what works exactly as designed, because it uses BlinkWithoutDelay with a built in adjustable speed to make it blink faster or slower based on IR volume buttons up and down, which works great.
I took the fader scripts and tried to remove the delay() and substitute it with the BlinkWithoutDelay method which works great, only during the fade calculations, the IR receiver is ignored, and I am thinking this is because it is busy making calculations, or, it does not see enough reason to interrupt the code and take me back to ground zero in the code.
UKHeliBob:
I intend to rewrite the AutoIT code clean/tidy tools to work with C++, but I really want to tackle this first.
It will be as simple as run the EXE, select your ino or other file, then specify where to save it. It will remove empty lines, give the option to remove comments, and fix all tabs. (and more as the revisions flow)
I think the problem with your understanding of the purpose of an interrupt. You're looking at it like the bell at a speed dating event: once you hear it, you stop talking to the person you are talking to and go talk to someone else. In reality, however, an interrupt is more like a doorbell. If you're making dinner and the doorbell rings, you answer the door then go back to making dinner.
Arrch:
Hmm.. Is there a way I can make it more the speed dating type? I was hoping to do this by saying " once the bell rings, see if its yellow, and if it is, stop what you are doing, and call this function"
That is what I hope to do, only because I dont want the code to stop every time it picks up one little Ir blip. Just want it to be able to be interrupted when it sees a certain code come in through IR.
MrKovacic:
Not in a way I care to describe.
What you need to do is restructure the bulk of your code so that it doesn't block, and it doesn't use for loop/delays. You want to be polling for data as often as possible. Here is a simple example demonstrating how to do that using a simple LED fade in which the fade up/fade down is determined by the state of a switch.
The first example will not allow you to "interrupt" the fading; you have to let the cycle finish before you can change direction:
const int ledPin = 13;
const int switchPin = 2;
const unsigned long fadeInterval = 20;
  pinMode(ledPin, OUTPUT);
  pinMode(ledPin, INPUT_PULLUP);
  int switchState = digitalRead(switchPin);
  for (int i=0; i<=255; i++)
    if (switchState == HIGH)
      analogWrite(ledPin, i);
      analogWrite(ledPin, 255-i);
    delay(fadeInterval);
To allow it to respond more quickly to the switch, you can rewrite it like this:
unsigned long lastFadeTime = 0;
int pwmValue = 0;
  if (millis() - lastFadeTime > fadeInterval)
    lastFadeTime = millis();
      pwmValue = constrain(pwmValue+1, 0, 255);
      pwmValue = constrain(pwmValue-1, 0, 255);
    analogWrite(ledPin, pwmValue);
The latter sketch allows us to poll the switch's state much more often than the former sketch.
*Disclaimer: I didn't compile or test these sketches
Arrch:
MrKovacic:
int pwmValue = 0;
That is a good explanation, however I am able to have it change speeds, and the switching mechanism according to your code is a physical switch, where I use Infrared.
The goal I am looking to accomplish is, if the IR receiver picks up the code: 0x96B47, it simply resets. That is the simplest form I can put it in, because on reset, there is no longer a previous value to determine what the script should be doing.
Is that possible?
If IR sees 0x96B47, then reset the arduino. While waiting for that code, let the fades work.
