It's generally a good idea to not only tell them, but also to tell them why. ![]()
The 3 flashes is the Arduino bootloader, basically letting you know it's alive!
In the future, if the LED stays constantly lit, even after a Reset, and you're not allowed to upload to the board.. that means you need to burn a new bootloader. (the bootloader is just basically a "program" on the chip, if you will, that allows you to upload to the Arduino using a Serial connection. Without the bootloader, you would have to use a programmer to program the board, which is another $20 at least.)
