What I mean by this title/subject is for the LED on my Mega 2560 board to turn on when it encounters a 1 in the code and turns off when it encounters a 0 in the code. Is this possible?
if (someVariable == 1)
digitalWrite(someLed, HIGH);
if (someVariable == 0)
digitalWrite(someLed, LOW);
Or the shortform version:
digitalWrite(someLed,someVariable?HIGH:LOW);
To test on a specific bit use the & (and) operator:
digitalWrite(someLed,someVariable&0x01?HIGH:LOW);
digitalWrite(someOtherLed,someVariable&0x02?HIGH:LOW);
etc.
To use the build-in led you can use the reference LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
ro_har_:
To precisely what "code" do you refer here?
My guess is that the OP is not ready for the ternary operator and as has been pointed out we don’t know exactly what he/she wants to do anyway
UKHeliBob:
I am quite new to Arduino and raspberry pi style of coding, I did a bit in my college course a couple of years ago but now wanting to learn more as I have a job interview for software developer coming this next week.
You may have left it a little late
Can you please explain what you mean by
What I mean is that someone will put in 10 1s and 0s, then you would click run and when it notices a 1 the light flashes, or something along those lines.
I assume that the user will input the 10 1s and 0s using the Serial monitor
What have you tried so far ?
ro_har_:
I've never earned a dime writing C++ code but here goes:
Your interviewer asks you to write a simple program to demonstrate your skills, something like -
ro_har_:
... someone will put in 10 1s and 0s, then you would click run and when it notices a 1 the light flashes, or something along those lines.
How would you write this? Pseudo code acceptable.
You can do this using a bitmask.
Umm....Good Luck.
dougp:
The problem is I have not done any software developing since college and that was only computer based, we did not use raspberry pi's, luckily this interview is for a level 1 training position, so I just have to show a willing to learn software development. Along with a written test.
Even if you can't program I would expect you to be able to draw a flowchart showing the steps required or an explanation of how the program would work
What would come first ?
What next ?
What tests are needed ?
What do you do with the results of the tests ?
How would you read the next input ?
How do you know that you have read all of the input ?
UKHeliBob:
Draw a flowchart showing the steps required
Yeah that sounds quite a good idea as I do still know a bit about flow charts (would need to research them a little).
Don't over think it
Pencil and paper
Boxes for actions
Diamonds for tests
Flow charts!
Oh my!
Don't mock. They are very useful in visualising the paths through a program and making sure that there are no loose ends (literally) Just because they are old school does not make them any less useful. How would you approach the task ?
Paul__B:
Flow charts!Oh my!
Ah, you prefer Nassi-Shneidermann diagrams
Sounds like the OP has a dev career in the bag.
