I am looking for the data sheets of the LEDs provide in the student kit. Since it looks like the forward voltage is dependent of the current who flows inside it, I need to find their reference to be able to search for the constructor data. Any idea where I can find that?
In order to do that you need to know the manufacture and part number for your particular LED. The only people who might know that are the makers of the kit.
It is very likely that they will not know because I suspect they buy them in batches from whoever has them in stock at the time.
However as the LEDs are not going to be anything special you could use a typical data sheet. Most of the parameters are determined by the material they are made from.
If you are really concerned about forward voltage drop against current then make a curve your self from a number of measurements.
Make sense.
It would be a great add for a student kit to provide them, since it is something you will study a lot in your future.
Thanks for the feedbacks @Grumpy_Mike and @LarryD.
But LEDs (like all diodes) are non-linear... The resistance changes with voltage (and current). With more voltage and more current, the resistance goes-down.
With LEDs we usually aren't too concerned with the exact voltage as long as we have enough voltage available.
Usually, we try to get the right current and the voltage "falls magically into place". This is the opposite of almost everything else in electronics where we apply the correct voltage and the current "falls into place". (Ohm's Law is always true but we have to apply it differently with LEDs.)
