LED Game Table code conundrum
Hello,
I’m an Arduino noob and somehow just got done building an LED coffee table capable of playing 8-bit games (gasp). But with me, some is never enough - I always want to push the envelope.
Speaking of, my coding skills are basically non-existent but I was wondering - I have ordered a USB Host shield to add to the project to allow me to hook up a physical controller to the project, but the games are all only 1 player. Is there a way to re-write these codes to allow for two player games? For example, the pong game (code below) is always played against a computer opponent. If I were to hook up two controllers, how would I re-write the code to allow for the second player to be controlled by a second serial input?
/* LedTable
 * Written by: Ing. David Hrbaty
 * Main code for Pong game
#include "pongCommon.h"
unsigned long curTime;
unsigned long prevUpdateTime = 0;
void pongInit(){
  scorePlayerLeft  = 0;
  scorePlayerRight = 0;
  FIELD_WIDTH * FIELD_HEIGHT;
  positionPlayerLeft  = FIELD_HEIGHT/2;
  positionPlayerRight = FIELD_HEIGHT/2;
  ballx = FIELD_WIDTH/2;
  bally = FIELD_WIDTH/2;
  velocityx = 1;
  velocityy = 0;
  ballBounces = 0;
  gameSpeed = 180;
  lastAutoPlayerMoveTime = 0;
  rumbleUntil = 0;
  waitUntil = 0;
void runPong(){
  pongInit();
  boolean pongRunning = true;
  while(pongRunning){
    if (scorePlayerLeft == MAX_SCORE || scorePlayerRight == MAX_SCORE){
      pongRunning = false;
    checkBallHitByPlayer();
    if((curTime - lastAutoPlayerMoveTime) > AUTO_PLAYER_SPEED) {
      if(moveAutoPlayer()) {
        lastAutoPlayerMoveTime = curTime;
    ballx += velocityx;
    bally += velocityy;
    checkBallOutOfBounds();
    clearTablePixels();
    // Draw ball
    setTablePixel(ballx,bally,WHITE);
    // Draw player left
    for (int y=positionPlayerLeft-PLAYER_HEIGHT/2; y<=positionPlayerLeft+PLAYER_HEIGHT/2; ++y){
      setTablePixel(0, y, BLUE);
    // Draw player right
    for (int y=positionPlayerRight-PLAYER_HEIGHT/2; y<=positionPlayerRight+PLAYER_HEIGHT/2; ++y){
      setTablePixel(FIELD_WIDTH-1, y, YELLOW);
    showPixels();
    boolean dirChanged = false;
    do{
      readInput();
      if (curControl == BTN_EXIT){
      if (curControl != BTN_NONE && !dirChanged){//Can only change direction once per loop
        dirChanged = true;
        setPosition();
      curTime = millis();
    while ((curTime - prevUpdateTime) <250);//Once enough time  has passed, proceed. The lower this number, the faster the game is
    prevUpdateTime = curTime;
  fadeOut();
void setPosition(){
  switch(curControl){
    case BTN_DOWN:
      if(positionPlayerLeft + (PLAYER_HEIGHT-1) / 2 < FIELD_HEIGHT-1){
        ++positionPlayerLeft;
    case BTN_UP:
      if(positionPlayerLeft - PLAYER_HEIGHT / 2 > 0) {
        --positionPlayerLeft;
    case BTN_START:
    case BTN_LEFT:
    case BTN_RIGHT:
void checkBallHitByPlayer() {
  if(ballx == 1)
    if(bally == positionPlayerLeft)
      velocityx = 1;
      ballx = 1;
      ++ballBounces;
      rumbleUntil = curTime + 200;
    else if(bally < positionPlayerLeft && bally >= positionPlayerLeft - PLAYER_HEIGHT / 2)
      velocityx = 1;
      velocityy = max(-1,velocityy-1);
      ballx = 1;
      bally = positionPlayerLeft - PLAYER_HEIGHT / 2-1;
      ++ballBounces;
    else if(bally > positionPlayerLeft && bally <= positionPlayerLeft + (PLAYER_HEIGHT-1) / 2)
      velocityx = 1;
      velocityy = min(1,velocityy+1);
      ballx = 1;
      bally = positionPlayerLeft + (PLAYER_HEIGHT-1) / 2+1;
      ++ballBounces;
  else if(ballx == FIELD_WIDTH-2)
    if(bally == positionPlayerRight)
      velocityx = -1;
      ballx = FIELD_WIDTH-2;
      ++ballBounces;
    else if(bally < positionPlayerRight && bally >= positionPlayerRight - PLAYER_HEIGHT / 2)
      velocityx = -1;
      bally = positionPlayerRight - PLAYER_HEIGHT / 2-1;
      ++ballBounces;
    else if(bally > positionPlayerRight && bally <= positionPlayerRight + (PLAYER_HEIGHT-1) / 2)
      velocityx = -1;
      bally = positionPlayerRight + (PLAYER_HEIGHT-1) / 2+1;
      ++ballBounces;
void checkBallOutOfBounds() {
  if(bally < 0)
    velocityy = - velocityy;
    //bally = 0;
    bally = 1;
  } else if(bally > FIELD_HEIGHT-1)
    bally = FIELD_HEIGHT-2;
    //bally = FIELD_HEIGHT-1;
  if(ballx < 0)
    velocityx = - velocityx;
    velocityy = 0;
    bally = FIELD_HEIGHT/2;
    ++scorePlayerRight;
    ballBounces = 0;
    waitUntil = curTime + 2000;
  else if(ballx > FIELD_WIDTH-1)
    velocityy = 0;
    ++scorePlayerLeft;
    ballBounces = 0;
boolean moveAutoPlayer()
  if(bally < positionPlayerRight)
    if(positionPlayerRight - PLAYER_HEIGHT / 2>0)
      --positionPlayerRight;
      return true;
  else if(bally > positionPlayerRight)
    if(positionPlayerRight + (PLAYER_HEIGHT-1) / 2 < FIELD_HEIGHT -1)
      ++positionPlayerRight;
      return true;
  return false;
I’ll keep this brief, just wondering if this was feasible before I go any further. Please ask any questions and I’ll get back ASAP. Thanks!
Hmm. This really stretches the definition of "question." :) If you want somebody to come up with a solution for you, maybe check out the Gigs/Collaborations forum.
