Hey guys,
Just started messing with 16x2 LCD screens. I'm getting gibberish characters after my output readings for an analog pot.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int numReadings = 10;
int readings[numReadings]; // Array for average
int index = 0;
int total = 0;
int average = 0;
const int analogInPin = 0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
int prevValue = 0; // For limiting
// initialize serial communications at 9600 bps:
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
lcd.begin(16, 2);
total= total - readings[index];
readings[index] = analogRead(analogInPin);
total= total + readings[index];
index = index + 1;
if (index >= numReadings)
index = 0;
average = total / numReadings;
sensorValue = analogRead(analogInPin);
outputValue = map(sensorValue, 0, 1023, 0, 255);
average = map(sensorValue, 0, 1023, 0, 255);
analogWrite(analogOutPin, outputValue);
if (average!=prevValue) {
lcd.setCursor(0,0);
lcd.println(average);
delay(10);
average = prevValue;
Does the LCD actually work? Have you tried:
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.println("hello");
And then do nothing else. Does that work?
Also I don't see how this will work:
int index = 0;
int total = 0;
If the readings can be an int, surely you need a bigger number to hold the total (10 ints)?
There is no documentation of lcd.println ever exists. The only documented printing method is lcd.print, there is no ln.
OK, well:
lcd.print("hello");
Or this, even, following on from the thread about streaming:
#include <Streaming.h>
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd << "hello";
void loop () {}
Thanks, works now. Got rid of the "println" and replaced with "print".
Now I just have to update it so that when there aren't 3 digits and it rolls down to 1, it doesn't leave the residual numbers there.
int index = 0;
int total = 0;
[/quote]
That was just copied and pasted right from the smoothing example. But that is a very good point. It should be a Long and not an Integer.
thedefog:
I normally print a few extra empty spaces as a sloppy way to erase residual numbers:
lcd.print(" ");
If desired, you may use sprintf to control exactly how many digits to output and what kind of padding etc. This will be total control at the cost of a few K of FLASH.
lcd.print(" ");
Thanks for the info. I'll try both.
