LED GPS Speedometer Not Registering Speed
I'm trying to make a speedometer that will change colors depending on the speed on which I am traveling.
If the speed is decreasing at any time or below 5 mph LEDs be red.
And if the speed is above 5 mph or increasing speed the LEDs will be a different color.
I am using an Adafruit 24 NeoPixel ring for LED's and a u-blox NEO-6 GPS module.
And the GPS is sometimes not registering the speed or any other GPS values and not switching colors when speed is at certain values or when it is increasing or decreasing. It tends to stay only one color no matter the speed. Also the GPS is not registering speeds above zero when I ride my bike or in a moving car.
I added a picture of the values I am getting, it seems to be connecting to satellites and getting correct GPS coordinates but as soon as I as I take it to real world test, the speed inst changing and LEDs are not changing. I also included a picture of the Arduino configuration I am using.
I am a very new to coding so any help would be very grateful.
(if anyone could help with the accelerating and decelerating code to that would be absolutely amazing!!!!)
#include "TinyGPS++.h"
#include "SoftwareSerial.h"
#ifdef __AVR__
#include <avr/power.h>
#endif
#define LED_PIN  6
#define LED_COUNT 24
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_RGB + NEO_KHZ800);
SoftwareSerial serial_connection(10,11);
TinyGPSPlus gps;
int val = 0;
int prev;
  #if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  strip.begin();
  strip.show();
  strip.begin();
  serial_connection.begin(9600);
  Serial.println("Project Red Stop");
prev = val;
val = gps.speed.mph();
//int val = speedM;
 while(serial_connection.available())//While there are characters to come from the GPS
    gps.encode(serial_connection.read());//This feeds the serial NMEA data into the library one char at a time
  if(val <= 0)
  //   if(speedM < 5 & val--)
    Serial.println("Speed MPH:");
    Serial.println(gps.speed.mph());
    Serial.println("Satellite Count:");
    Serial.println(gps.satellites.value());
    Serial.println("Latitude:");
    Serial.println(gps.location.lat(), 6);
    Serial.println("Longitude:");
    Serial.println(gps.location.lng(), 6);
    colorWipe(strip.Color(0,100,0), 100);
   // strip.setPixelColor(0, strip.Color(0,100,0));                   // gps works faster with this:
    strip.show();
    delay(10);
  else if(val < prev) {
    strip.show();
    delay(10);
  else if(val > 0)
  //   else if(speedM > 5 & val++)
    colorWipe(strip.Color(0,100,100), 100);
    strip.show();
    delay(10);
  else if(val > prev) {
    strip.show();
    delay(10);
void colorWipe(uint32_t color, int quick) {
  for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
    strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
    delay(0);                           //  Pause for a moment
