Led laststate toggle with delay
Hi there
Need some help pls
With a toggle led and button, how to add a delay millis() at the end where:
if (relayState == 0) {
digitalWrite(pin2, relayState);
So if the button was pressed, and led comes on, begin timer for 5 seconds and switch back off until next press
int relayState = HIGH;
int lastButtonState;
int currentButtonState2;
const byte buttonPin = 8;
const byte buttonpin2 = 9;
const byte pin2 = 2;
const byte pin3 = 2;
  while (!Serial);
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(buttonpin2, INPUT_PULLUP);
  pinMode(pin2, OUTPUT);
  pinMode(pin3, OUTPUT);
  digitalWrite(pin2, HIGH);
 currentButtonState2 = digitalRead(buttonpin2);
 //// Button Overide
    lastButtonState    = currentButtonState2;      // save the last state
  currentButtonState2 = digitalRead(buttonpin2); // read new state
  if(lastButtonState == HIGH && currentButtonState2 == LOW) {
    Serial.println("Button is pressed");
    // toggle state of relay
    relayState = !relayState;
You can do something like this code fragment:
// if button press detected somehow,  begin a timer
uint32_t buttonPressAtMs = millis() ;
// sometime later, test if the timer has expired (5 seconds)
if ( millis() - buttonPressAtMs > 5000 ) {
   // if the relay is still on, switch it off here
This looks rather odd:
If you add another, it could even be Irish - "to be sure, to be sure, to be sure ". :rofl:
that's an example for a retriggerable monostable multivibrator (Monotflop). To be precise: two multivibrators with one button and one LED each.
The idea behind is that one button and one LED are building a logical unit. Therefore the variables are held in a struct. Each unit (group) needs a timestamp(millis) for timekeeping, therefore there is a member variable to keep the previousMillis.
As you want several button-LED units ... it uses an array of struct.
The sketch can be adopted easily for more button-LED combinations.
modify the pin definitions to your need:
  by noiasca
  http://werner.rothschopf.net
const byte ontime = 5;   // on time in seconds
struct Groups {
  const byte buttonPin;
  const byte outputPin;
  uint32_t previousMillis;
Groups group[] {
  {8, 2, 0},  // index 0: button Pin, outputPin, previousMillis
  {9, 3, 0}   // index 1: check if you really want to use this output pin ...
void tickButtonLed()
  for (auto & i : group)
    if (digitalRead(i.buttonPin) == LOW) {
      digitalWrite(i.outputPin, HIGH);
      i.previousMillis = millis();
    if (millis() - i.previousMillis > ontime * 1000UL && digitalRead(i.outputPin) == HIGH)
      digitalWrite(i.outputPin, LOW);
    pinMode(i.buttonPin, INPUT_PULLUP);
    pinMode(i.outputPin, OUTPUT);
  tickButtonLed();
if you don't mind to use google translator, you can read more about here:
[url]https://translate.google.com/translate?sl=de&tl=en&u=https://werner.rothschopf.net/202003_arduino_retriggerbares_nachlaufrelais.htm[/url]
