LED Light not toggling
Hi
I have merged to sketches I found on the internet a http post and a toggle switch. Both work perfectly fine individually.
The toggle switch makes a http post to my webserrver, this is working perfectly fine but for some reason the LED light that is supposed to turn on/off isn't. I have loaded the original sketch back in place and the led toggles.
I use the same if statement to call the http post as toggle the LED. I can't see whats wrong I was hoping someone with more knowledge than myself, not hard learning very much as I go, would be able to have a look and point out my silly mistake.
thanks jasemilly
//zoomkat 4-04-12
//simple client test
//for use with IDE 1.0
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
//the arduino lan IP address { 192, 168, 0, 102 } may need
//to be modified modified to work with your router.
#include <SPI.h>
#include <Ethernet.h>
//toggle variables
int inPin = 2;         // the number of the input pin
int outPin = 13;       // the number of the output pin
int LDR_Pin = A0; //analog pin
int state = HIGH;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
//network variables
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 0, 50 }; // ip in lan assigned to arduino
byte gateway[] = { 192, 168, 0, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
byte myserver[] = { 192, 168, 0, 34 }; // zoomkat web page server IP address
EthernetClient client;
void setup(){
  //Ethernet.begin(mac, ip);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  Serial.println("Better client test 4/04/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
   reading = digitalRead(inPin);
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendPOST(); // call sendPOST function below when byte is an e
  // if the input just went from LOW and HIGH and we've waited long enough
  // to ignore any noise on the circuit, toggle the output pin and remember
  // the time
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
     Serial.println("button press");//test
    if (state == HIGH){
      state = LOW;
      sendPOST();
      state = HIGH;
      sendPOST();
      time = millis();
digitalWrite(outPin, state);
previous = reading;
void sendPOST() //client function to send/receive POST request data.
  String PostData="url=http://192.168.0.34:81/tenHsServer/tenHsServer.aspx?t=ab&f=ToggleDevice&d=E3";
  if (client.connect(myserver, 80)) {
    Serial.println("connected");
    client.println("POST /WestCroft/urlencode.php HTTP/1.1");
    client.println("Host:  192.168.0.34");
    client.println("User-Agent: Arduino/1.0");
    client.println("Connection: close");
    client.println("Content-Type: application/x-www-form-urlencoded;");
    client.print("Content-Length: ");
    client.println(PostData.length());
    client.println();
    client.println(PostData);
  else {
    Serial.println("connection failed"); //error message if no client connect
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
outPin is not defined as an output.
Could that be a problem I wonder, because they default to being inputs otherwise.
//toggle variables
The first and last statements here do not belong in the same sketch. The Ethernet shield communicates with the Arduino using SPI, which, for the 328-based Arduinos means pins 11, 12, and 13.
Thanks guys defined the output properly and it worked like a charm!!
I checked my code several times and never spotted!!
