LED light Strips coding help fade effects
Hi, would anyone be willing to help? there are a few things I'm trying to adjust on my code.
I have 6 144leds WS2812B LED strips with the flora V3. The strips are being used in a costume. 4 from the waist to the ground in a skirt, and two over each shoulder connecting at the waist with the others.
I wanted to have the lights gradually brighten and fade up from the ground when the lights first come on but I can only get the fade to loop and not start and go to the next stage.
I also was trying to work out some different effects I can include, similar to the fade I wanted a watery effect like a waterfall. I have absolutely no idea how to create this and if anyone is willing to help it would be much appreciated!
class Strip
  public:
    uint8_t   effect;
    uint8_t   effects;
    uint16_t  effStep;
    unsigned long effStart;
    Adafruit_NeoPixel strip;
    Strip(uint16_t leds, uint8_t pin, uint8_t toteffects, uint16_t striptype) : strip(leds, pin, striptype) {
      effect = -1;
      effects = toteffects;
      Reset();
    void Reset() {
      effStep = 0;
      effect = (effect + 1) % effects;
      effStart = millis();
struct Loop
  uint8_t currentChild;
  uint8_t childs;
  bool timeBased;
  uint16_t cycles;
  uint16_t currentTime;
  Loop(uint8_t totchilds, bool timebased, uint16_t tottime) {
    currentTime = 0;
    currentChild = 0;
    childs = totchilds;
    timeBased = timebased;
    cycles = tottime;
Strip strip_0(144, 6, 144, NEO_GRB + NEO_KHZ800);
Strip strip_1(144, 12, 144, NEO_GRB + NEO_KHZ800);
struct Loop strip0loop0(1, false, 1);
struct Loop strip1loop0(1, false, 1);
//[GLOBAL_VARIABLES]
  //Your setup here:
  strip_0.strip.begin();
  strip_0.strip.setBrightness(70);
  strip_1.strip.begin();
  strip_1.strip.setBrightness(10);
  //Your code here:
  strips_loop();
void strips_loop() {
  if (strip0_loop0() & 0x01)
    strip_0.strip.show();
  if (strip1_loop0() & 0x01)
    strip_1.strip.show();
uint8_t strip0_loop0() {
  uint8_t ret = 0x00;
  switch (strip0loop0.currentChild) {
    case 0:
      ret = strip0_loop0_eff0(); break;
  if (ret & 0x02) {
    ret &= 0xfd;
    if (strip0loop0.currentChild + 1 >= strip0loop0.childs) {
      strip0loop0.currentChild = 0;
      if (++strip0loop0.currentTime >= strip0loop0.cycles) {
        strip0loop0.currentTime = 0;
        ret |= 0x02;
    else {
      strip0loop0.currentChild++;
  return ret;
uint8_t strip0_loop0_eff0() {
  // Strip ID: 0 - Effect: Rainbow - LEDS: 144
  // Steps: 100 - Delay: 20
  // Colors: 2 (180.255.255, 0.0.150)
  // Options: rainbowlen=67, toLeft=false,
  if (millis() - strip_0.effStart < 20 * (strip_0.effStep)) return 0x00;
  float factor1, factor2;
  uint16_t ind;
  for (uint16_t j = 0; j < 144; j++) {
    ind = 57 - (uint16_t)(strip_0.effStep - j * 0.8507462686567164) % 57;
    switch ((int)((ind % 57) / 28.5)) {
      case 0: factor1 = 1.0 - ((float)(ind % 57 - 0 * 28.5) / 28.5);
        factor2 = (float)((int)(ind - 0) % 57) / 28.5;
        strip_0.strip.setPixelColor(j, 0 * factor1 + 0 * factor2, 155 * factor1 + 0 * factor2, 160 * factor1 + 255 * factor2);
      case 1: factor1 = 1.0 - ((float)(ind % 57 - 1 * 28.5) / 28.5);
        factor2 = (float)((int)(ind - 28.5) % 57) / 28.5;
        strip_0.strip.setPixelColor(j, 0 * factor1 + 0 * factor2, 0 * factor1 + 155 * factor2, 255 * factor1 + 160 * factor2);
  if (strip_0.effStep >= 57) {
    strip_0.Reset();
    return 0x03;
  else strip_0.effStep++;
  return 0x01;
uint8_t strip1_loop0() {
  uint8_t ret = 0x00;
  switch (strip1loop0.currentChild) {
    case 0:
      ret = strip1_loop0_eff0(); break;
  if (ret & 0x02) {
    ret &= 0xfd;
    if (strip1loop0.currentChild + 1 >= strip1loop0.childs) {
      strip1loop0.currentChild = 0;
      if (++strip1loop0.currentTime >= strip1loop0.cycles) {
        strip1loop0.currentTime = 0;
        ret |= 0x02;
    else {
      strip1loop0.currentChild++;
  return ret;
uint8_t strip1_loop0_eff0() {
  // Strip ID: 1 - Effect: Rainbow - LEDS: 144
  if (millis() - strip_1.effStart < 20 * (strip_1.effStep)) return 0x00;
  uint16_t ind;
    ind = 57 - (uint16_t)(strip_1.effStep - j * 0.8507462686567164) % 57;
        strip_1.strip.setPixelColor(j, 0 * factor1 + 0 * factor2, 155 * factor1 + 0 * factor2, 160 * factor1 + 255 * factor2);
        strip_1.strip.setPixelColor(j, 0 * factor1 + 0 * factor2, 0 * factor1 + 155 * factor2, 255 * factor1 + 160 * factor2);
  if (strip_1.effStep >= 57) {
    strip_1.Reset();
    return 0x03;
  else strip_1.effStep++;
  return 0x01;
Please use the Autoformat tool in the IDE.
Then, use the Copy for Forum tool in the IDE.
Then, paste your code here, where you will see it in a code block with a standard formatting, which will vastly increase the attention it gets.
TIA
a7
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Your topic was MOVED to its current forum category as it is more suitable than the original
