I am quite new to Arduino programming, but have a live project that needs to be installed next week with a completely working system. Fortunately I dont think what i need to do is terribly complicated, just slightly beyond my reach at the moment.
Basically I will be using and Arduino Mega to control a relay board connected to 10 different LED strips. I have a megnetic hall effect sensor which is connected to one of the Megas digital pins. Every other time the sensor is triggered, I need one of the LED strips to turn off. I also need a timer to start after the first trigger for 30 seconds, after which all the lights that are currently will turn back on and the system can start again.
I hope i have made a clear explanation of what I am looking for. I do have a working model that I made through the Grasshopper plugin Firefly, but the code wont compile properly and doesnt work on the board.
Using the Arduino IDE I can turn off all the lights in order each after a certain amount of state changes, but my major problem that i cant seem to find a solution for the timer and reset 30 seconds after the first state change.
Any help pointing me in the right direction would be much a appreciated, and anyone willing to help out with some code will be reimbursed for their time accordingly.
As I say, I need this to be up and running asap for an installation next week. Need a working model hopefully by Tuesday.
Many thanks
Jak Drinnan
Nicholas Alexander, Creative Construction
