LED Lightsaber Build Power/Driver Question
Hi, the only reason that I can see soooo many LEDs in parallel without current limit resistors surviving like that is the Op was lucky to get all his LEDs from the same batch, and the volt drop is extremely close to each other.
Do you have any hot spots in the length of the sabre if you leave it on for about 5 minutes. I mean hot spots in the light part of the sabre.
Tom....... :slight_smile:
