LED Lightsaber Build Power/Driver Question
raschemmel:
The driver is rated for 8.25 W which is 1 watt more than a colored christmas tree bulb. Note the flat brass colored back surface This should be mounted with thermal paste to a round metal disk attached to the end of a metal tube that forms the skeleton of the light sabor. The heat from the driver will travel down the shaft and dissipate to the air.
Sounds good! I'll be sure to mount it directly to the lightsaber. ]:slight_smile:
