I am communicating with a scrolling LED marquee using a python script, instead I would like to send the serial data myself
This is what I tell it in the terminal:
do you have a datasheet of the scrolling LED marquee thingie?
The python script merely sets all kind of commandstrings to get certain effects / fonts etc. These are just ascii strings (saw no binary in my quick scan) so easy to mimic yourself. If you call the script with the debug flag you will get the whole string in your console window. And you will see the codes otherwise send to the board.
The python script contains quite a lot of codes, you only have to port that to an Arduino sketch e.g in the form of a Serial.print(""); for snowflake effect
Have you tried the debug flag yet? then you will see what needs to be send. So please post the debug output.
The help does not tell me what the serial data is, just how to control the script.
The debug flag just calls up the help again
toledo version 0.0.4.3
Always use flags --message and --output last
-h (--help) This screen
-v (--version) Show toledo version
-p (--port=) Set the port for use (default /dev/tty.usbserial)
-d (--debug) Enable debug mode (verbose, call this flag first)
-s (--sid=) Which Sign ID is in use (default 00)
--intro= Set the intro effect (1-16)
--exit= Set the exit effect (1-11)
--bell= Add a noise to your sign (0-4)
--speed= Set the movement speed (1-4)
-f (--font=) Set the font used (1-5)
-c (--color=) Set color on supported boards (red, green, orange,
ired, igreen, iorange, rog, gor, rainbow
--page= Which page to progam (A-Z)
--runpage= Run which programmed page (A-Z) (non-functional)
--link= Run which pages in which order (A-Z)
-l (--line=) Specify line to program, on supported boards (default 1)
--raw= Send protocol specific commands
Include the FULL string to send, everything between
<IDn> and XOR checksum
-m (--message=) Set the desired message (call this flag before output)
-o (--output) Output to sign (call this flag last)
example: ./toledo.py --link="ABACAB" --output
example: ./toledo.py -p "/dev/tty.usbserial" -m "Holy Toledo" -o
example: ./toledo.py --intro="1" --exit="5" --speed="2" --inverse --page="B"
--line="2" --message="Holy Toledo" --output
The manufacturer in china sent me the specs! Its all in there but I still dont get it
I need to create one serial command to change "pages" from A to Z
