hello
I made this circuit
and this code
int latchPin = 4; // pis connected to shift registors
int clockPin = 5;
int dataPin = 3;
int pins [8] = {6, 7, 8, 9, 10, 11, 12, 13}; // common cathode pins
byte A[8] = { B00000000, // Letters are defined
B00011000,// you can create your own
B00100100,
B01000010,
B01111110,
B01000010,
B01000010,
B00000000
byte B[8] = { B00000000,
B11111100,
B10000010,
B10000010,
B11111100,
B10000010,
B10000010,
B11111110
byte blank[8] = { B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000
byte R[8] = { B00000000,
B01111000,
B01000100,
B01000100,
B01111000,
B01010000,
B01001000,
B01000100
Serial.begin(9600); // Serial begin
pinMode(latchPin, OUTPUT); // Pin configuration
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
for (int i = 0; i < 8; i++) { // for loop is used to configure common cathodes
pinMode(pins[i], OUTPUT);
digitalWrite(pins[i], HIGH);
for (int k = 0; k < 1000; k++) { // showing each letter for 1 second
display_char(A);
display_char(B);
display_char(R);
// add more letters show method here
void display_char(byte ch[8]) { // Method do the multiplexing
for (int j = 0; j < 8; j++) {
digitalWrite(latchPin, LOW);
digitalWrite(pins[j], LOW);
shiftOut(dataPin, clockPin, LSBFIRST, ch[j]);
digitalWrite(latchPin, HIGH);
//delay(1);
shiftOut(dataPin, clockPin, LSBFIRST, B00000000); // to get rid of flicker when
digitalWrite(pins[j], HIGH);
and I get the following result
1er image
second image
3e image
I notice that there is always a line of led high .and if I changed this part of code
byte A[8] == { B00000000,
B10000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000
I get two led high (first and last ).
second question how get a text Scrolling?
