LED matrix 8x32, explain the code please
Hi everyone :sunglasses: please could you explain this code, the code works fine but I want to understand the sequence, especially “HT1632C functions” >> work of this code is when you add 1 letter or number via serial port it is appear on LED Matrix 8x32, thats all :grin:
#include "aipointe.h"
// HT1632C PINs
#define DISPLAY_CS    3
#define DISPLAY_WR    4
#define DISPLAY_DATA  5
// HT1632C Commands
#define HT1632C_READ    B00000110
#define HT1632C_WRITE   B00000101
#define HT1632C_CMD     B00000100
#define HT1632_CMD_SYSON  0x01
#define HT1632_CMD_LEDON  0x03
// Display buffer
byte buffer[32];
  Serial.begin(57600);
  // all PINs are output
  pinMode(DISPLAY_CS, OUTPUT);
  pinMode(DISPLAY_WR, OUTPUT);
  pinMode(DISPLAY_DATA, OUTPUT);
  // enable System oscillator and LED duty cycle generator
  ht1632c_send_command(HT1632_CMD_SYSON);
  ht1632c_send_command(HT1632_CMD_LEDON);
  // clear display
  ht1632c_clear_display();
  if (Serial.available() > 0) {
    int incomingByte = Serial.read();
    displayChar(incomingByte);
void displayChar(int incomingByte) {
  // get font details
  int infoPosition = incomingByte - 33;
  unsigned char length = aipoint_info[infoPosition].length;
  unsigned int offset = aipoint_info[infoPosition].offset;
  // select display
  digitalWrite(DISPLAY_CS, LOW);
  // send WRITE command
  ht1632c_send_bits(HT1632C_WRITE, 1 << 2);
  // send start address, 00h
  ht1632c_send_bits(0x00, 1 << 6);
  for(int i = 0; i < 32; i++) {
    if(i < length) {
      char mychar = pgm_read_byte(aipointe_font + offset + i);
      ht1632c_send_bits(mychar, 1<<7);
    else ht1632c_send_bits(0x00, 1<<7);
  // unselect display
  digitalWrite(DISPLAY_CS, HIGH);
//  HT1632C functions
void ht1632c_clear_display() {
  for(int i = 0; i < 32; i++) ht1632c_send_bits(0x00, 1<<7);
void ht1632c_send_command(byte command) {
  ht1632c_send_bits(HT1632C_CMD, 1 << 2);
  ht1632c_send_bits(command, 1 << 7);
  ht1632c_send_bits(0, 1);
void ht1632c_send_bits(byte bits, byte firstbit) {
  while(firstbit) {
    digitalWrite(DISPLAY_WR, LOW);
    if (bits & firstbit) digitalWrite(DISPLAY_DATA, HIGH);
    else digitalWrite(DISPLAY_DATA, LOW);
    digitalWrite(DISPLAY_WR, HIGH);
    firstbit >>= 1;
Hi, what exactly does the sketch do now? What happens each time you send a character from the serial monitor?
Paul
the character will appears on LED matrix, of course the character go to "aipointe.h" to get the font.
again
OK if you open serial port and write "A" then you pressed "Enter" >> "A" will appear on LED matrix
and if you write for example "STAR" the code just takes the last letter "R" and appears on LED matrix
Ok, I think I understand the code now. What do you need to know?
