Ok.This is my solution but I'm sure this is not the smartest one. it draws a "+" exploiting persistence of vision.
const int latchPin = 8;//Pin connected to ST_CP of 74HC595
const int clockPin = 12;//Pin connected to SH_CP of 74HC595
const int dataPin = 11; //Pin connected to DS of 74HC595
void setup ()
pinMode(latchPin,OUTPUT);
pinMode(clockPin,OUTPUT);
pinMode(dataPin,OUTPUT);
int dat = 0x18;
int dat2 = 0x81;
I'm really sorry.
Yes it is the running code I was talking about but i pasted it wrong :D.
      Â
void setup ()
int dat = 0x18;
int dat2 = 0x81;
shiftOut(dataPin,clockPin,MSBFIRST,dat);
digitalWrite(latchPin,HIGH);
digitalWrite(latchPin,LOW);
shiftOut(dataPin,clockPin,MSBFIRST,dat2);
delay(9);
//__________________________________________________________________________________Â Â
dat = 0x7e ;/*colonne*/
dat2 = 0xe7; /*righe*/
delay(9);
I managed to display scrolling letters but now I want to stop them. How can I change the code suggested by that tutorial?
or is there a better method to do the same thing?
I didn't succeded in stop them manipulating the code I suggested (link), but I somehow managed to display a "+" with the code I posted just above. I don't know if this is the smartest way to do it :(.
It draws 2 photograms extremely quickly: one represents 2 vertical lines,
The sunfounder code is just demo code. It's definitely not the smartest way to do it (in a way that would give you a useful display). Because the timing is done using for loops, you can't just stop it. Not simply.
There are 8x8 libraries out there, you should look for one.
