LED Matrix Backpack 8x16 help!
Hello I am trying to manipulate the code from this adafruit instructional for myself (Overview | Adafruit Microphone Amplifier Breakout | Adafruit Learning System).
The only difference is, instead of me using an 8x8 bicolor led matrix, I am using a 8x16 single color matrix (16x8 1.2 LED Matrix + Backpack - Ultra Bright Square Green LEDs : ID 2042 : $16.95 : Adafruit Industries, Unique & fun DIY electronics and kits). I understand I need to change the call from "Adafruit_BicolorMatrix matrix = Adafruit_BicolorMatrix();" to "Adafruit_8x16matrix matrix = Adafruit_8x16matrix();" however, what else in the code do I need to change to make this scrolling sound meter led display work so that theres 8 rows and 16 columns. I have also attached the general code below:
Scrolling Sound Meter Sketch for the
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
// Include the Matrix code for display
//replaced from: "Adafruit_BicolorMatrix matrix = Adafruit_BicolorMatrix();"
const int maxScale = 8;
const int redZone = 5;
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
   matrix.begin(0x70);  // pass in the address
   unsigned long startMillis= millis();  // Start of sample window
   unsigned int peakToPeak = 0;   // peak-to-peak level
   unsigned int signalMax = 0;
   unsigned int signalMin = 1024;
   while (millis() - startMillis < sampleWindow)
      sample = analogRead(0);
      if (sample < 1024)  // toss out spurious readings
         if (sample > signalMax)
            signalMax = sample;  // save just the max levels
         else if (sample < signalMin)
            signalMin = sample;  // save just the min levels
   peakToPeak = signalMax - signalMin;
   // map 1v p-p level to the max scale of the display
   int displayPeak = map(peakToPeak, 0, 1023, 0, maxScale);
   // Update the display:
   for (int i = 0; i < 7; i++)  // shift the display left
      matrix.displaybuffer[i] = matrix.displaybuffer[i+1];
   // draw the new sample
   for (int i = 0; i <= maxScale; i++)
      if (i >= displayPeak)  // blank these pixels
         matrix.drawPixel(i, 7, 0);
      else if (i < redZone) // draw in green
         matrix.drawPixel(i, 7, LED_GREEN);
      else // Red Alert!  Red Alert!
         matrix.drawPixel(i, 7, LED_RED);
   matrix.writeDisplay();  // write the changes we just made to the display
bump...anyone?
Instead of being so ambitious, you might want to take the first step of writing a sketch that can write to one LED at a time. You need to understand how the library you are using works.
